Alutrix 600 - this little collection (enough for 120m2) was over £1600!
I have somewhere between little and no interest in doing this again, it’s very hard on the old knees!
it had better be bloody amazing for that level of investment :oops::oops:
I took myself down a real wormhole of warm roof design last week… I wasn’t even going to bother with a vapour barrier until I spent an evening googling it!
It’s a minefield/nightmare and a world of pain if I get it wrong as the roof structure could apparently rot away - I’m doing what I can within reason to avoid that eventuality as plan on staying here for a long time!
C
Cal919
Vapour barriers are important. What you using above?
C
Cal919
We always use a product called protan, well i say we our roofers install it. Its all just heatguned on the joints is very good for flat roofs.
Pleasant Saturday spent on my own in shed sorting out a broken gatepost for some security gates. Got the little Ajax saw cleaned up and set up. Coolant belt was off and tank gormed up. Cleaned up and washed out with Kerosene. Repaired the pipe with some 10mm copper. Need to get some proper coolant.
Taking me back to childhood using the saw.
First time welding in 20+ year and first time using a stick welder since I was a teenager. Quite humbling to be starting from scratch. Final result is clearly pretty s**t, but will hold up to the job hopefully. Need some bigger rods as I only had 1.6mm which wasn’t helping. Much more practice required.
What’s the stainless tie thing doing in the middle?
We always use a product called protan, well i say we our roofers install it. It’s all just heatguned on the joints is very good for flat roofs.
My roof is just a big flat rectangle with sides, so am covering it with a single piece of rubber (ie no joints) as I would like to think there is less chance of us cocking that up!…
Nice paint job.
in all seriousness, bin the 1.6’s. I’m reasonable with stick but anything smaller than 2.5mm you need to be Yoda to get a good weld without slag inclusions, especially on anything that isn’t spotless. 2.5 at around 75-80 amps will do it. What welder do you have.
Nice paint job.
Jefferson 160amp. Chinese I expect but a well reviewed from local AG supplier
Picked up some thicker rods this morning .
