Which size trailer
Marker lights a great idea, have them on my LM105 and it really makes you (and other road users) know it’s there.
Decent twin lenses wide angle camera is also a game changer on a van. I can back blind round corners with this one (TT2515)
We were on about rear camera yesterday be handy for sure
W
weirdfish
Yes, 10” wheels, will 13” rims make that much difference?
LT105, 2000kg, didn’t want or need anything bigger, we live up a very steep hill that just keeps going and going, learnt my lesson when towing a 3 ton digger, (2200kg), on a plant trailer up here, the gearbox didn’t like it and blew an oil pump seal and wrecked a bearing.
This way I won’t be tempted to tow too much weight🙈😂👍
What was the tow vehicle?
W
weirdfish
Ssangyong korando sport pick up.
Decent Mercedes engine but their own box, maybe a weak spot or just too much weight up a very steep hill.
It's a weak spot I'm afraid. I've been dragging 2.8 ton diggers around Dartmoor for 14 years with barely any incident other than normal wear and tear. Defender and Discos.
Gearbox will probably s**t itself this week now I've said that😂
usable low box is your friend. My main complaint with Japanese 4WD. Can’t use Low box without fecking difflock trying to rip itself apart
Will changing the 10” rims to 13” make that much difference apart from soak up the shite roads a bit better
10" tyres get a lot hotter at speed and blow out more frequently ... if you're changing tyres anyway get some 13" rims and go to Saveros
had mine from these guys for the Ifor
spent 600 quid 're-shoeing' all my trailers back in May -- age had killed them all - some looked like new - apart from the cracking - just couldn't trust them :rolleyes:
W
weirdfish
I can get 4 brand new 13” rims with tyres for £200
165R13, will they be ok seeing as they’re slightly wider than 145’s on there at present.
Also, does anyone know the offset I need for them to fit ok.
Have a look at your old rims, it should be stamped on them ET something
