Which size trailer
W
weirdfish
Will depend on what you are likely to be carrying. I went for 8 ft ramps so that it isn’t as steep to load. 6 ft ramps are better suited to beaver tail trailers.
Not planning on loading/carrying any particular items, apart from maybe the occasional ride on mower.
It was more for, “just in case “ moments that I thought I would look out for a set.
As a bit of an update, and more questions 🙈😂
New boots fitted and marker lights on the front so as I can see the trailer when it’s hitched up.
Question, I’d like a set of ramps for it, length wise what’s the rule of thumb for trailers.
Measuring underneath I think the storage area will take 8’ ramps, but I notice 6’ ramps are also available, what would you guys go for?.
depends really on what you're loading up 'em, but generally speaking the longer the better = lower slope angle and not such a sharp 'break over' point off/onto the ramps onto/off the trailer bed ;)
The longer the better, especially for things like mowers that can ground out over the breakover point.
As other said as long as possible ramps, also as @Stroppymonkey said you can get a one piece tail board ramp for an LT.
You also will need some black tape to cover most of the white part of those lights leaving just a small bit showing, if you can see them in your mirrors you wont see much else behind in the dark. :ROFLMAO:
W
weirdfish
It will be like the blitz all over again😎😂👍
W
weirdfish
I never normally apply the handbrake on the trailer, just ends up sticking on when you come to use it after sitting for a while, but for some reason I thought I would this time and guess what? ( please see pics 🙈)
Might also be time for the springy thing as well, ( I did wonder why it had tape on it).
can buy al the bits for hydratows
