I was thinking something less wasteful.. I can burn Kero! Mebbe some used engine oilHeating oil should do as a thin anti corrosion agent…
May as well keep the oil in the bund clean?I was thinking something less wasteful.. I can burn Kero! Mebbe some used engine oil![]()
Just waxoyl it.I was thinking something less wasteful.. I can burn Kero! Mebbe some used engine oil![]()
No tilty on? Didn’t need to spin it 6 ways to tip into the trailer under the roof?Dug the shed floor out today, Rarely bother with ‘small’ dumpers anymore and just use the dump trailer instead.. only going around the back of the shed(literally behind digger in the photo) to the crusher stockpile so all good inspector gadget!
Don’t need a tilty for ripping concrete up! Less height the better under a shed as well, surprising how big a machine becomes when your working under things!No tilty on? Didn’t need to spin it 6 ways to tip into the trailer under the roof?
Is that a basic spec machine no pat boom and 6 way blade like doobins ? lol hahaha![]()
Imagine how tidy you'd get it once you put the tilty back on!Cleared a ditch out today, 260 meters in a day didn’t think that was too bad considering I had to dig the whole thing out! Ran 4 loads into a low spot as well.. will be drilled tomrrow! BBQ time!!
View attachment 64180View attachment 64181
260m sounds good going ..not done any ditching with the scandi grader ...do you not bother with a v bucket ?Cleared a ditch out today, 260 meters in a day didn’t think that was too bad considering I had to dig the whole thing out! Ran 4 loads into a low spot as well.. will be drilled tomrrow! BBQ time!!
Tilty was onImagine how tidy you'd get it once you put the tilty back on!![]()
Don’t have a v bucket.. if I was pulling new ditches for fun I’d definitely be getting one!260m sounds good going ..not done any ditching with the scandi grader ...do you not bother with a v bucket ?
My other LL would quite like it to burn down so he can replace it (he says)You only pay £600 a year to rent a shed… which you fill with flammable juices.. bargain![]()
Around here a setup like that will you a bust from HMRCBit wet today. My clean oil tank was empty and dump tank was full so had a couple hours polishing and cleaned up 1600 litres of waste kerosene down to 1 micron and took any water out of it as well. Still have the last 1400 litres of Therma 35 at the back of the shed that we are slowly burning our way through (left over dregs from a commercial job 5 years ago) This shed costs me £50 a month and whilst it more than earns its keep I would like to move my kit to a space of my own one day.
Nothing dodgy going on as far as HMRC concerned... probably best not talked about to with insurance company thoughAround here a setup like that will you a bust from HMRC![]()
Honestly never tried removing dye. Certainly doesn’t come out in the filters .How well does red clean up?
Asking for a friend
