Seriously now....you've got the space and the machine big enough why not knock up a temp? shelter for this winter?
16ft square with a slight lean and just use SHS and chuck 16ft sheets on top.
Even just 4 decent posts think big gazebo...Be a doddle to knock up and then just weld a big loop in middle and shift about with dremas grab?
I couldn't be arsed scratting about outside if we have a winter like this again..
Neighbours can't do owt as it's temp plus prob not even see it if no sides on...
wind!! ..... had to nail the trampoline down Sunday and it wasn't the blowy-est its ever been up here :rolleyes:
Oh come on ..80mm shs well fabbed with self tapped sheets. Weld plates on bottom to stack blocks in...won't go anywhere
that was my thoughts on a sealed, closed polytunnel with over half a tonne of sand bags holding it down to the planet .. it still ended up in the field next door one very gusty night .. 's why I made it the base frame - know where you're coming from, but that's 500 quidsworth of materials 'fore you even start :rolleyes::(
have been considering a slide out roof off the top of the boxes for a while, but same issue .. material costs for summat that's only supposedly temporary :unsure:
yesterday had loads of interruptions/can you justs so progress was sloooow
wanted to get some sort of coverage on the bits I'd had to play about with on the Tico and also had to deal with the case drain union which wasn't in the greatest of states - just rotating - only tapered adaptor I had was a used one, but it had to do and wound in well :cool:
coat of Firwood's Pewter - real quick drying - keep the rust at bay
then wrestled the Tico into its new home
dug out some hoses ( these run my BIG grab usually) and had to play about a while with available fittings, 'til i managed to find enough to get it sorted - was well happy to find some 1/2" ISO A males - thought I was stuck with the 'stack' I'd originally assembled
this morning was a 'kid morning' in town, while Vicki had her hair cut .. then deliver them later to have theirs done too, so again not a lot achieved today ..... I did however manage to get this sorted when we got back
having lifted it down off the bench I made the elementary mistake of forgetting to add a case drain line, 'fore giving it a little oil ...
fortunately for me I'd left the cap only finger tight ...
the spray was 'considerable' though :rolleyes::censored: ..
so after i'd cleaned that up and wiped it all off the winch cradle frame :oops::rolleyes:
I went and found my breaker T line adaptor, I made/cobbled/assembled from available bits, some time ago for the fork mast's single acting set up -- and cobbled up a temp. line for that to meet the case drain union
and gave it a little more oil - winch ran sweet and a lot faster than little jake's 1/4" lines could achieve ...
will have to see if I can hunt out a 3m, 3/8" line to replace the cobble to the 1" FF QC, T line..
got a spare inch male to go on the end of it ...
save using the fork mast 'cobble' / adaptor, to get the single acting mast back down, once you've oiled it up -- connect the second side of the service to tank ;):giggle: works real well -
7.5m jib going on there now?
What's the swl going to be for your setup, are you planning reeving a few times
not quite Mike ... that would be OTT :LOL:
the Drema has load sensing on the hydraulics, which should give a reasonable 'cover' ... she'll do 10t, in close :giggle:;)
me box of 40mil.s arrived yesterday lunchtime so swapped them out with the temporary ones before Serge, my genny mate arrived with his missus for the afternoon, 'fore going out for some scoff down the village at tea time.
Have had better steak, ale and mushroom pies :rolleyes: ..
the place has changed hands recently though :(
.. then rejigged the case drain line to an FF QC and put all the lines away in the dry ... crap night forecast
expecting it to be a pretty grim day this morning, so not much anticipation of doing a lot, but was dry 'til 2-ish and then only relatively light and warm with it .... rian didn't stop play 'til we'd finished
emptied the two remaining cage baskets of nice dry firewood into the little Countax trailer and ferried it back and forth to the wood shed
Pam's been taking a few pix too
turned into a proper grey ol' day
cages emptied, she thought we'd finished ..... er no !
got two more bags sat yet
tried to get 'em both on but had to come back for #2 :giggle:
over hanging the tailboard too much and wasn't confident it'd all get there, so discretion ruled and did two trips
half filled the wood shed though .... got a pile more to collect from Russ's place - must get it done 'fore the weather turns to complete crap :rolleyes:
kids are back in school, the weather's been cr*p and all sorts of other tish needed dealing with so .. not a lot done ... and in the odd times we have managed the odd dry hour outside the garden's needed some sorting ready for - you know what.
this lot took some burning...
dry day today and got some bench time .. and damn me ...Pam's been at it again !
yet another pile of crud to burn .. a friend of her's gave her a plant a while back and it had bloody convolvulus in its roots ... spreads like a wild fire and she's now hell bent on eradicating it .. but it has to be burnt (along with anything/everything else it comes into contact with) !! :(:mad: gonna take some burning :(:cry:
I on the other hand have had a slow, but productive - ish day ...
has taken an inordinate amount of time to get what looks like very little done ....
in between several quite long phone calls -- Vicki got a letter from LA last week - demanding they trim their hedge (which we've already done recently), but they wanted more off --
been trying to get hold of the 'author' for the last five working days for an explanation of exactly what they want doing?? ..
actually returned my multiple calls/ansafone messages today - thought he'd never stop talking ...
no sooner finished with him and got another jobsworth on asking why I'd not responded to his email??? --
" that'll be because I've not had it, probably "
had to traipse down the house, turn the 'puter on and check for him :(:rolleyes:
" No it's not in spam either Huw -- send it again please "
" Ah .. my apologies, I mis-typed the address -- have you got it now? " :unsure:
so he then proceeded to read the bloody thing out and go through the ins and outs of a ducks back side ... :mad:
he's the private water supply officer for the LA (jobsworth) ... all 50 odd lines of text .. finally got shot of him an hour later with a
" yeh, I'll reply to you shortly, when I've had a chance to digest it all and gather together the info. you're looking for ":rolleyes::mad:
so as said, been a slow day on the progress front .. getting these lugs in the right spot, right centres and completely aligned after I'd knocked out the frames was 'time consuming' :rolleyes::unsure::(
then had to ream the paint out of the holes and get the pins free sliding
for a trial fit
#1 done and went on fine (y)
#2 went a bit quicker with 'the drop on it and slipped in sweet as ....
had the third frame assembled, but grub time got in the way of further progress ...
went back to it after tea, only to be interrupted by yet another looooooooong phone call .. which got curtailed when me battery died :giggle::oops: hardly surprising the amount of use it's had today
so much for getting the third one done .. job for anon ... and it's a double yoker ... 8 holes to align :oops::oops::censored: .. gonna be Fun - wiv a big eff :unsure:o_O
got to be in town for 08.00 in the morning, take Harper to nursery, in town and then back out here, with Clara to take her to school for 09.00 ...
Vicki's school have changed their hours, so has to be in 20 min.s earlier now, but does get to 'finish' (technically) at 15.00 - never happens that way though :rolleyes::mad:
then pick up Clara at 15.15 and back to town for her swimming lessons at half four .. Tuesday's a busy day ... MIGHT get a chance at #3, but I doubt it - realistically - we'll see?? :unsure:
Band saw time after that :rolleyes:
well that arrangement changed quick ...
in for eight, drop Harper AND Pam at nursery, bring Clara back out here to school, then back to town - hit Aldi and Morrisons then wait for Pam to show ...
Harper is three tomorrow and Pam wanted to find a bit more for her, than she'd already acquired... I was wrapped and ready to roll by half ten - no show - no answer on her phone - eventually rang me at eleven
" where are you? "
" As arranged, I'm trying to kill time in Morrisons - finished the two lists half an hour ago " :rolleyes::rolleyes:
" Ah "
Kid's clothing shop she wanted to go to wasn't open 'til after lunch :mad: - didn't notice the sign in the window for half an hour, stood waiting for it to open :ROFLMAO:
got something equally nice in - you guessed - Morrisons :ROFLMAO: and we headed home - eventually :rolleyes::(
best part of the new arrangements was that Clara is getting picked up with her besty's dad .. she also goes to swimming lessons tonight :cool:
so got the rest of the day to myself, which was progressing .... 'til the heavens opened, despite a blue sky day forecast :mad:🤬🤬
two sets welded, two stitched and it lashed it down ....
still doing it - can't see any signs of an improvement either ....
they couldn't forecast accurately, what's happening outside their own office window 😡🤬
forgot to say the other night, had a bit of a suss out for the feasibility of a.n.other box of the 20ft variety, as discussed in the container thread recently ...
had a bit of a measure up and gave some thought to relocating/rearranging where stuff is parked
mark on the floor for L/H front corner (as you face it)... t'other is behind the corner of the genny - 24ft, parallel from the fronts of my other three ... would /(will) go a treat
also had a juggle of me trailers ... have been wanting to move the 6t tipper I had off Ollie Kitchin for a while, as there was a huge pile of dead leaves under it in need of being despatched, before this season's 'arrive'
I know what that one weighs, but thought I'd weigh the others, so's I can mark 'em up
525kgs for the Ifor
me 10 x 5 came in at 625 once you deduct two spares and my circa 80kgs off there - had to stand on the mudguard to get the shot of the dynamometer
and the little 8x4 was 250kgs including the spare
then tucked 'em all away out the way, but easily accessible to get at when required
.. gonna have to make inroads into losing those tyres :rolleyes::giggle:
also knocked a little lift beam out for .....
I can't get it off the floor and lifted it into the box with the ' Drema a week or two ago in a couple of slings .. this'll make lumping it about a bit easier hopefully -- I'll weigh it some time out of interest .. took three of us to get it in the boot of the Kia, when it came home.:rolleyes:
and ..... this was Saturday night's rain :oops::oops:
... unreal downpours on/off all Sat. evening and then threw it down all night
Soon be November 5th, annual clearance night 👀
hell's teeth ... they'd smoke in some order ... would need a bloody good southerly gale blowing to get rid of the smell .. next farm over'd not be impressed :ROFLMAO::ROFLMAO:
well that's 4 hrs of my life I won't get back ... haven't done it for about two weeks and looked like it was gonna chuck it down this morning .. not 'sposed to but didn't look promising - turned out real nice eventually
WP_20240918_13_07_45_Pro.jpg WP_20240918_13_14_43_Pro.jpg WP_20240918_13_16_44_Pro.jpg WP_20240918_13_17_02_Pro.jpg
I'd had enough of raking it all up by half two :rolleyes::censored: .. the bank on the left can wait
then went back to me bench
so .... although I've not put much up lately ... been busy
this took some getting right/perfectly bang on square/parallel/ true .... lots of squares, careful measuring, cutting and setting out
and allowing for variations in material straightness/accuracy ...
but got there quietly
plus a lot of calculating spacings/centres
for load transferral / distribution
had a day off, last Saturday for a shopping trip - co-ordinated by FB MP . Chippenham first for these ...
5t x 6fts, with the bonus of a.n.other carriage ... Stonehouse for the inclinable indexing / dividing head that @Rob65 had already spotted
and Cheltenham for a lovely 4 jaw for me Harrison ...
6 hrs and 154 miles later, was unloading them, 'fore tea ..... would've been 5 hrs if i hadn't got caught up in Usk show's traffic queues, which they'd 'stacked' out in all the country lanes from Raglan down to Usk - unbelievable - my route into England is always Raglan, Devauden, Itton, Chepstow and over the old bridge ... so much shorter than the others -- and quieter - normally :mad: :mad:
anyway ... 400kgs of six footers, got 'offed' 'fore tea and t'other bits stashed away for anon ....
when i collected the forks, I'd asked the guy if we could slip them off the carriage to lay 'em down and the carriage flat, in the trailer .. in fairness he'd made a bit of an effort -- in vain -- soon became apparent the next morning as to why he'd sold them ..
fork latches snapped and obviously didn't have the tech/nouse/whatever to sort it, to separate/adjust their positions ...
hour later and some hole cleaning, they were out and I'd gotten it in bits :giggle: and'd given most of the rack a bit of a clean up of all the burrs;)
then it was back to ......
and a trial fit, 'fore dealing with the lateral stiffening ....
and I'm out of pix
