Best towable excavator (over next 10 -20 years)
Sat in this today. Interesting machine. 34.5k with buckets/hyd QH and single aux. Blade float and stick steer AND pedals. All controls fully electronic so you can dial speeds on each service and swap to Backhoe pattern if you wanted 🤣
2800kg and not zero turn but probably comparable to E27 with its tiny bum? Everything seems easy to get to, whole cab tips up for access like a forward control truck.
I was quoted 31.5k for one with no aircon but hydraulic hitch buckets and twin aux.
Its a real peach to grade with but felt noddy with just a grading bucket and wouldn’t do any other function whilst tracking.
Makes it seem a bit dear down in Devon. Allegedly you can run the blade on the RH joystick whilst tracking and steering with left?.
250kg counterweight available for a price.
I wonder how good they'll be in 10 years time but time will tell. The valve block is electrically controlled Vs pilot hoses as is normal.ALOT of electrical gimzmos to potentially start playing up. They're made in China so you do get alot of machine and features for the money because that's what you can achieve when relying on cheap labour
Tilting cab? Pfft my 16 year old takeuchi has that.
Forestry gear is usually electric servos and they run very high hours.
Hg2702
Hg2702
Might have a low houred 302 for sale …
As I say it might be fine- but wasn't really sure what was wrong with the pilot hoses. Less space I guess. Imagine if you got a mouse in there though- disaster.
Allegedly better residuals on used CAT compared to other brands…. But sales always say what you want to hear …. Certainly doesn’t look like a headache free option for 10-20 years as per title, lots of software in there, even the joysticks have chips in
Means the cab can lift up for access o suppose, have to say the layout was pretty sweet, loads of room around everything. As per convo the other day about BHL, CASE running electronic pilots in the 90s and seems to be still AOK. Friend of mine had to spend £800 for a new joystick / block on his Kubota 2.7t so I guess all options can bite you.
Hg2702
Hg2702
Christ all this in 10 years time stuff of rubbish , these machines have been about 5 years now and counting … expect they said the same about the wheel
Things change caterpillar wouldn’t f**k about for the sake of it
To be honest everything seems to have pretty good residuals in the main stream brands. Tak, kub, Volvo, Wacker and the rest etc all seem to hold their money. It's like anything the more s**t on a vehicle be it car or machine the more to play up. Id sooner a more basic but brilliantly put together machine where the paint stays on and you don't get cracked welds Vs a hi spec machine where they've tried to cram as much stuff in as poss half of which is basically unnecessary to the day to day operator
Hg2702
Hg2702
To be honest everything seems to have pretty good residuals in the main stream brands. Tak, kub, Volvo, Wacker and the rest etc all seem to hold their money. It's like anything the more s**t on a vehicle be it car or machine the more to play up. Id sooner a more basic but brilliantly put together machine where the paint stays on and you don't get cracked welds Vs a hi spec machine where they've tried to cram as much stuff in as piss half of which is basically unnecessary to the day to day operator
Only thing I’ve bust in the cat is a hydraulic pipe ! But your right the radio is shite
