other than a 20A toggle James ;) ...think Russel was proposing to do a two way circuit he could switch on/off from either location in the truck :unsure: ... lot of faff though for the distances involved between switches ... and finding suitable toggles, although switching a low draw, like the relay broadens the availability of suitable switches dramatically (y)
Use a Diode then if you don’t want to load the switch. Fitted in the switching wire from the reverse lights.
I’ve missed something though, as your taking about switching from different locations?
Left hooker
Left hooker
Just careful messing with the wiring on those shogun's as they are flyby wire and the controllers don't like unapproved items added
Hg2702
Hg2702
Not technically my job but it’s next to our yard !
Finally decided to do sommat about my micro bucket not fitting the titl hitch. It will be ideal for delicate jobs loading the muck truck (like tomorrow's :rolleyes:)
Twenty minutes work with the plasma and welder. So glad of my workshop. Just cut out the protruding round stock and welded in a bit of flat to give it enough clearance.
K
Komatsu
Talking of Plasmas, did anyone ever get to lidl and get one??
I can’t imagine they’d be much cop. My r-tech 50 amp plasma for £700 blows my previous generic Chinese machine out of the water
A good starting point would be,what type of torch do they run?
Mintsauce
Mintsauce
Nice that colour is spot on. Looking for a 16/20 yard bin though 😉
sat in an 8x8 though Con, you could quote Doc Emmet Brown ..... "where we're going we don't need roads" :ROFLMAO::ROFLMAO::ROFLMAO:
