Simon edwards
Cheers guys,I reckon that wolf will be ideal,reasonable price compared to some on machine mart I was looking at.
SGS will do you the same thing for £382, go there. Wolf used to be value but having been bought out so many times they are now overpriced.Cheers guys,I reckon that wolf will be ideal,reasonable price compared to some on machine mart I was looking at.
didn't somebody have problems with these people a few weeks ago ? ... had to get a refund? and that's only a 90 litre tankSGS will do you the same thing for £382, go there. Wolf used to be value but having been bought out so many times they are now overpriced.
Maybe they had a problem with SGS but the compressor is exactly the same. I have the larger tank I think, it's from SGS and it's been faultless.didn't somebody have problems with these people a few weeks ago ? ... had to get a refund? and that's only a 90 litre tank
here's a 90 ltr Wolf
Wolf 100128 90L 150PSI 240V 3HP 14CFM Belt Drive Twin Cylinder Air Compressor for sale online | eBay UK
Find many great new & used options and get the best deals for Wolf 100128 90L 150PSI 240V 3HP 14CFM Belt Drive Twin Cylinder Air Compressor at the best online prices at eBay UK! Free delivery for many products!www.ebay.co.uk
I'd be going for the bigger receiver but could always Tee an additional tank in (old 47kg propane bottle makes a good add on tank)
yeh was with SGS .... couldn't get them to deliver and eventually had refund IIRC .... the compressors are all generic and identical, 'cept for colour schemes, so I see no issue -- just depends who's willing to take the lowest profit margin I 'sposeMaybe they had a problem with SGS but the compressor is exactly the same. I have the larger tank I think, it's from SGS and it's been faultless.
What does one do about draining down the extra lpg tanks? And where can you get fittings for them that aren’t regulators?yeh was with SGS .... couldn't get them to deliver and eventually had refund IIRC .... the compressors are all generic and identical, 'cept for colour schemes, so I see no issue -- just depends who's willing to take the lowest profit margin I 'spose
I'd want the 150 ltr tank though, but if it's a fixed location install, there'd be no issues with tee-ing in additional storage capacity with a few old gas bottles ----- all tested way beyond SWP on the 'pressors.
The hard bit is finding a reverse thread fitting to screw in to the top.What does one do about draining down the extra lpg tanks? And where can you get fittings for them that aren’t regulators?
Can you not just use pigtail?The hard bit is finding a reverse thread fitting to screw in to the top.
nah ...The hard bit is finding a reverse thread fitting to screw in to the top.
turn the bottle upside down and let it goWhat does one do about draining down the extra lpg tanks? And where can you get fittings for them that aren’t regulators?
not a bad idea thatCan you not just use pigtail?
BES.co.uk | Next Day Delivery On 15,000 + Plumbing Supplies
Order 1.5m POL x W20 propane pigtail assemblies and other LPG products online at BES.co.uk. Low Prices, Free Next Day Delivery Available, 15k Plus Products in stock. P/N: 16852www.bes.co.uk
Obvs might need to refit new airline hose and elephant ear clip
An adapter is certainly the easiest, but you loose out on the high-flow from the Aux tank.nah ...
any good welding supplies place should keep them and a variety of threaded spindles ... they not all 26tpi .. some are std BSP
I usually bore the spindle necks out to a decent size hole, but yeh losing the cylinder valve is an option for even more flow rateAn adapter is certainly the easiest, but you loose out on the high-flow from the Aux tank.
The tanks I've used have an ordinary BSP thread once you get the valve out, so you can just use plumbing fittings (uk tanks may be quite different).
Also, if you mount the tank upside down, it doesn't accumulate water - but it will go out the delivery line, so a separator is probably necessary.
