spent a couple of hours Sunday sorting out our nice neighbours' water system for them ......
had had F*lt*rcle*n come and take a look at it and supposedly service it and what a balls of it they made ...
basically it was taking an hour to fill a bath .....
his tanks and pump set up are circa 5-6m below his bath ...
there's huge head capability on these pumps -- like 40m
first thing they'd done was rip him off 350 quid (plus VAT) for a 180 quid (inc VAT), Nocchi Pentair Jetinox pump unit ( have the same in my system - great pumps) ..
'cos it wasn't pumping?-
supposedly (if it had been an issue a new impellor is only about 20 quid and they're totally rebuildable
New pump was cutting in out continuously and the trickle out of his kitchen tap was pitiful ....
first things first - how's the filter? ....
God knows why but this guy'd put a paper filter in it ..
blocked solid with fine particulate ...
ripped that out and stuck a 1 micron string wound in, from my stock ... better ..
looked at the gauge he has in the system - under a bar ..
this knob had wound his pressure switch down ...
'cos he'd failed to check the charge pressure in the pressure vessel ... 0.9bar
emptied the system down in the pump compartment and recharged the vessel to 1.7bar - refilled it all and wound the pressure switch back up to 1.7 too
pump working as it should and his plumbing in the house has never been so good ...
one very ecstatic neighbour ...
didn't dare ask him what these pr*cks'd charged him in all
and to add insult to injury .. said to him give me the old pump and I'll have a look at it and rebuild it if needed ....
Bar stewards had taken it with them - his bloody pump FFS
God knows how folks go through life, unable to do anything for themselves, having to pay for everything - and then worst of all - getting ripped off in spades, by pr*cks like this mob
anyways .... in light of James' issues I thought I'd take stock of my 'spares' situation Monday
I knew I had a couple of 'old' 1.5bar fixed pressure switches ...
one with a split diaphragm, that i'd managed a repair on with superglue as a temp fix, waiting for a new unit to arrive
and another with a suspect controller unit .....
so dug them out .... pulled 'em to bits and built a good un out of the two
then found two new ones I'd bought mega-cheap off fleabay a while ago, lurking in the bottom of the box these two'd been stashed away in .....
so think i'm covered on the pressure switch front for a while ... usually last about 5+years, from experience -- should see me out
but I do want one for another pressurised water system I want to install here, to give me a pressurised circuit up on me patch
then damn me yesterday .... pump kept cycling here with no 'cause'
traced it/nailed it down to the upstairs cistern, dribbling and overflowing, (into the pan), ever so slowly, but enough to drop the system and vessel pressure to bring the pump on, every half hour or so
piece of crap plastic guts in it, which I've had apart before, quite some time ago .....
dual flush thing, ultra silent fill, with the weirdest
ball valve I've ever seen
completely stripped to find the culprit - little scale flake in the tiniest of orifices in this weird 'valve', holding it ever so slightly open
been good all day today, so think I nailed it
problem with a pumped supply is the slightest of leaks/drips/whatever, will run the pump ... any loss of water can't be tolerated, unlike mains, where a dripping tap causes no issues, aside from the drip drip, noise factor
