heritage machining
For a vac what about using a billygoat vac you can get them that empty into a trailer mine empties into a bag but it only cost me 200 quid doesn't worry about wet stuff
Only downside is the muck goes through the fan but it's pretty heavily built sucks 20mm gravel no probs
12t chassis so doubt it.This one up for sale locally for £5000. Wonder how much the skid unit would weigh empty/stripped down/cut down to just the Vaccum unit and tank. If it could be slimmed down to 2700 kg ish then maybe interesting.
is the truck registered as plant? ... they could used to run on red diesel so not a goods vehicle ... I'd take a serious look into itThis one up for sale locally for £5000. Wonder how much the skid unit would weigh empty/stripped down/cut down to just the Vaccum unit and tank. If it could be slimmed down to 2700 kg ish then maybe interesting.
That was a mates few years back will suck half a 4" block up had dumper that did the tight places with a sealed lid on top the hose from truck would create the vacuum by a long hose and then a shorter hose would be used to hoover the ground up into the dumperThis one up for sale locally for £5000. Wonder how much the skid unit would weigh empty/stripped down/cut down to just the Vaccum unit and tank. If it could be slimmed down to 2700 kg ish then maybe interesting.
Plant is all white derv now?is the truck registered as plant? ... they could used to run on red diesel so not a goods vehicle ... I'd take a serious look into it![]()
That's hellsva bit of kit, and I think very cheap for what it is, but oversized for what I had in mindThat was a mates few years back will suck half a 4" block up had dumper that did the tight places with a sealed lid on top the hose from truck would create the vacuum by a long hose and then a shorter hose would be used to hoover the ground up into the dumper
Truck was at limit on weight so dirt had o be dumped out on the site
They did have a tracked one for off road Access also at one pointThat's hellsva bit of kit, and I think very cheap for what it is, but oversized for what I had in mind
You can drive that on a car license as it'll be registered as a digging machineThat's hellsva bit of kit, and I think very cheap for what it is, but oversized for what I had in mind
was about to say the same . .. no plating either ... probably reg. as special vehicles .. and yes will be on white nowYou can drive that on a car license as it'll be registered as a digging machineI was/am very tempted by it too.
I am waiting for a look at the log book. Unsure if exempt from O-Licensing though?You can drive that on a car license as it'll be registered as a digging machineI was/am very tempted by it too.
It will need plating under the new rules as it's based on a stock HGV chassis.... However those mercs are good reliable units and you'd transplant the unit onto another lorry chassis without issue.was about to say the same . .. no plating either ... probably reg. as special vehicles .. and yes will be on white now
Good excuse to buy a tractor I suppose!It will need plating under the new rules as it's based on a stock HGV chassis.... However those mercs are good reliable units and you'd transplant the unit onto another lorry chassis without issue.
IF your work was local enough I'd suggest mounting it as a FIXED trailer to a small tractor to get around it
should be ... no need to be reg. as goodsI am waiting for a look at the log book. Unsure if exempt from O-Licensing though?
I tend to agree, but Russ's Liebherr doesn't need plating on his stock Scania chassis (which seems odd)It will need plating under the new rules as it's based on a stock HGV chassis.... However those mercs are good reliable units and you'd transplant the unit onto another lorry chassis without issue.
but will not constitute ag classificationGood excuse to buy a tractor I suppose!
Yeah but if behind a tractor no one cares about anything. specially in Devonbut will not constitute ag classification
