I serviced my 2002 case cx130 yesterday and fitted new exhaust .
When I opened up the hydraulic oil tank I found this .
I completed service and fitted new filters including the hydraulic one .
I thought it might be better to change the oil so I went to do this today .
I started the machine to move it into a better position and I noticed the levers went really stiff once the revs were up , it was actually difficult to move them .
I then drained out the hydraulic oil tank and removed the strainer from the bottom of the tank .
The strainer had quite a bit of the filter in it .
I then changed the pilot filter . This was pretty clean.
There was another filter I’ve never changed before , a cardboard set up below the Pilot filter in this
It’s a cardboard affair , it was choked with bits of filter stuck in its outlet .
Initial thoughts are possible water in hydraulic oil rotted the filters but I’m not so sure now that I have drained the oil the state of it looks quite good .
I’m wondering if a faulty main by pass valve could cause this ? I think mine may be faulty as it can pull the engine down at times if working it quite hard . Could this create enough pressure to collapse the filter like that ?
Any thoughts ?
My plan at the moment is clean out tank , replace all filters and tank strainer as it’s slightly damaged . Fill it with hydraulic oil and try it out .
Then look at relief valve if it may of been the cause .
Any thoughts ?
