So much so here's pics to prove it
Last outing of winter holidays.
Yea same here, hope it stays for a whileAbsolutely stunning day
Zero wind and clear blue![]()
Ahar ..Where is it though!
Can't complain about cold winds they pull the wet off the ground quickerain't been bad here today either ... nasty N westerly though
So you live and work in one of the most wet and windy places in the UK, then you go holidaying in another which is about 10 minutes away?
There is a bit of er, jovial animosity 'tween the Yorks and the Lancs lot, (over some war we had hundreds of years ago) but i've concluded we're pretty much the same really.
Can't complain about cold winds they put the wet off the ground quicker
There is a lot of discussion going on in Gloucester at the moment regarding dredging. Now personally I can’t see that it makes much of a difference but I would say this. When we have the extent of flooding that we currently have. The water is very silty. It is not fast moving here so I guess some of that silt ends up in the bottom of the river, therefore raising it!!So round here, the Environment Agency have cur right back on dredging because of the damage to the aquatic environment. Now for the last three days the water dropped on the higher ground of the East Midlands is passing through every available water course in the Fens on its way to the sea, several rivers have topped their containment with albeit minor flooding, but if you could see the speed the water is carving through even minor man-made ditches and cuts, everything not anchored to the bottom is either being washed straight out to sea or getting minced up passing through the hundreds of pumping stations on the way through. They might just as well have dredged everything.
When the bottom silts it raises the bed so the watercourse is much wider and slower, so silting accelerates. When they dredge the water runs in the narrowest part and runs faster, which is a big issue where we have hundreds Of miles of watercourses with essentially no fall and relying on pumping to drain them.There is a lot of discussion going on in Gloucester at the moment regarding dredging. Now personally I can’t see that it makes much of a difference but I would say this. When we have the extent of flooding that we currently have. The water is very silty. It is not fast moving here so I guess some of that silt ends up in the bottom of the river, therefore raising it!!
So how much difference would it make to the extent of flooding we are seeing around Gloucester and Tewkesbury. My guess is not a lot.When the bottom silts it raises the bed so the watercourse is much wider and slower, so silting accelerates. When they dredge the water runs in the narrowest part and runs faster, which is a big issue where we have hundreds Of miles of watercourses with essentially no fall and relying on pumping to drain them.
On the m50 2 weeks ago where the flood area is, can't remember seeing it that highSo how much difference would it make to the extent of flooding we are seeing around Gloucester and Tewkesbury. My guess is not a lot.
When we have this extent I guess not a lot!!
Don’t know your area or how it’s looked after. I’m speaking about the area I know.So how much difference would it make to the extent of flooding we are seeing around Gloucester and Tewkesbury. My guess is not a lot.
I can sense your happinessbeen trying hard to snow here all evening ... very light covering on very dry ground ... hope it doesn't have a proper go overnight![]()
