here you go Dan - dare to be different ...... used to be a few of them knocking about this area and the Portaro Pampas too
might be a new 'collectable' ------ one day
been meaning to chuck this in here for a while ..... I'm sure a lot will find this a useful addition to their reference files ... took a bit of finding ;)(y)
I`ve got a couple of similar here, but files too large to upload.
managed to get a few bits done last week .. case of having to with this ... not been done in over two or three weeks .... took some cutting (and needs doing yet again already - too wet though, ATM with either heavy dew or frost, that needs to dry off)
broke meself in 'gently' with a small job the next day ...
took some splitting .... OK if you know where all the 'tags' are, but guessing where they were was hard going ..... one of Vicki's from school :rolleyes:
quite how the hell this belt came off is beyond me ??
Gave it all a good blast out and recovered several broken needles and pins from the guts, 'fore persuading it back together.
then went looking for why a.n.other machine controller wasn't performing ... easy answer once found ...
but with moulded plugs either end, achieving a decent looking repair, that'd pass PAT testing and look tidy was a slow process - shrink wrap, staggered soldered joint, more shrink wrap over the inners and a final wrap over the outer sheath looked reasonably respectable ... see what PAT-man says :rolleyes:
into town Monday for some money juggling and a CHAPS to the solicitor dealing with Vicki's new house ... spotted this in Morrisons' car park - it followed me in and sounded glorious :giggle:
couldn't work out what the motor was .. I'm sure @Furniss 'll have an idea .... bit naughty running round with race numbers on the sides - illegal in the UK, unless crossed through with some tape :rolleyes:
feeling significantly better this week end and been shifting firewood quietly with a barrow Sat./Sun., on/off ..... CNBA to extract the baskets from under the 8 or 9 lengths of 300 mil perf pipes that're sat on top of them, carry them down to the wood shed and empty them there ... barra seemed an easier option ... initially :rolleyes:
surprised just how much the shed held/took to fill
10 barrows
and another 15
cage and three quarters ... will probably take the last quarter cage AND a.n.other at least :rolleyes: ... still CNBA to shift the damned pipes though and the empty cages for the next one .... 'bout 14 very full barrow-fuls to a cage :) ... body felt ok -- feet were less so
's where I started from, after the last filling session back in August
two lovely days, but a bitter North wind kept the temperature well down all weekend :mad: with a real hard, white frost on everything Sunday morning :( Winter is approaching, but slowly ... lots of flowers still well out :oops: ... would like to get the grass massacred again, today if it dries enough ... rest of the week's is forecast pissy wet and 50+ mil. of rain ... but it's kids day today - little un' currently on nap time - not gonna last for long though :rolleyes: ........... and speak of the devil - she's yelling GRAND DAD !! :LOL::ROFLMAO:
had to drag my sorry arse into action these last couple of days .... exchange and completion looms on Vicki's new hutch shortly and time to start getting funds where I want them, instead of spread about in various places ...
finally exchanged today after a lot of faffing about with the sellers ...
expected three weeks left on the gas boiler inspection cert, to be acceptable -- think again - get it done or I keep the cost of a new boiler out of the offered price ...
you'd think I'd demanded a 100 yr guarantee on the bloody thing ..
what a **** about getting them to sort it.
"Would you pay thousands for a car, sight unseen, with three weeks MOT? ... nah me neither!! -- get it sorted " :rolleyes:
Completion next Friday morning - at last! :giggle: half term week ;)(y):cool:
as said else where ..... been to Simon's brother's place today ..... try and sort a 'bit of a problem' with his little Deutz traccy .... top link mount (which I welded back together a few years back) had snapped two studs holding it on and was looking very nadgered .. 14mm stepped studs down to 12mm ... ridiculous size for what they were doing.
Simon'd had a go at the one and'd failed to get the damned thing out, capped off by ending up off centre :(
but only just
so got him to strip all the extraneous bits an' bobs off it and loaded up a load of gear and headed over there this morning. Bucket full of #1MT, 14mm drills of varying lengths, some 18s and 19s, five new 14mm broaches and mount, couple of #3MT chucks, taps, wrenches etc. and plenty of Rocol........plus of course me Magtron and tranny.
No where near enough flat surface to get a grip so had to get creative ..
and wrestling 30+ks of mag drill into position called for a bit more lateral thinking
and gentle FLT handling
bloody broach mount didn't give me enough travel with the drill offset by 50mil on the plate so, had to cheat a bit and grab it in the 20m chuck I'd fortunately taken with me ..... once I'd gotten enough depth with that I could then swap to a 14mil drill, to give me a centre for a pilot hole, then back to the 14 mil drill to get the full depth .... a right p*ss about but got there in the end ......
then it was a case of very carefully repeat the process on the one Simon'd been 'at'
got there in the end with that too - eventually ...
and used the mag with the tap in the chuck to start it by hand
tapped out to M16 ... no choice (and the 14/12s were just too small for what this carries IMHDO)
taking the holes in the bracket out to 18 was another saga in itself ..... the bracket's spring steel ..... one drilled out sweet as ...... t'other one was a right bas**rd ...
out of oxy so couldn't get some selective heat into where I wanted to drill .. Plumber's little gas blow torch was like p*ssing in the wind ... must've sharpened the drill 30-40 time over the course of a couple of hours trying and eventually gave up ... coming to mine in the morning and I'll open the hole out either with some proper heat and a drill or simply wash it out with the torch ... got a 2mm deep guide to work to (which took a couple of hours to achieve) :rolleyes::mad::mad: took longer peeing about with that one hole than all the rest of it combined ... 's one bloody hard piece of spring steel
the 'offending' item getting repaired with some 299s a while back .. can't quite see the holes in question in the last pic ........ repair has held well for the last 18 months, considering the top link hangs on that spring
WP_20220528_12_52_21_Pro.jpg WP_20220528_12_52_25_Pro.jpg WP_20220528_13_08_38_Pro.jpg
to be continued ;):giggle:
Simon'd had a go at the one and'd failed to get the damned thing out, capped off by ending up off centre :( View attachment 52425
but only just View attachment 52426
No where near enough flat surface to get a grip so had to get creative ..View attachment 52429 and wrestling 30+ks of mag drill into position called for a bit more lateral thinking View attachment 52431 and gentle FLT handling
View attachment 52433 bloody broach mount didn't give me enough travel with the drill offset by 50mil on the plate so, had to cheat a bit and grab it in the 20m chuck I'd fortunately taken with me ..... once I'd gotten enough depth with that I could then swap to a 14mil drill, to give me a centre for a pilot hole, then back to the 14 mil drill to get the full depth .... a right p*ss about but got there in the end ......
View attachment 52432 View attachment 52430 and used the mag with the tap in the chuck to start it by hand
View attachment 52428 View attachment 52427 tapped out to M16 ... no choice (and the 14/12s were just too small for what this carries IMHDO)
out of oxy so could get some selective heat into where I wanted to drill .. Plumber's little gas blow torch was like p*ssing in the wind ... must've sharpened the drill 30-40 time over the course of a couple of hours trying and eventually gave up ... coming to mine in the morning and I'll open the hole out either with some proper heat and a drill or simply wash it out with the torch ... got a 2mm deep guide to work to (which took a couple of hours to achieve) :rolleyes::mad::mad: took longer peeing about with that one hole than all the rest of it combined ... 's one bloody hard piece of spring steel
View attachment 52434 View attachment 52435 View attachment 52436
Good to see you up and kicking again 🙂
so much for the forecast nice day ... got set up ready to sort the 19 mil hole for Simon, when he arrived and it pee-ed down and has been doing more of the same most of the day .. glorious start - 'til I wanted to do anything outside :mad:
had to lift the lump of UB out from where it was with lil' Jake ... could used to pick it up and put it where I wanted it :( not anymore :mad:
must've gotten a rain drop on the lens :mad: ... what you can't see is Simon stood holding the 4ft umbrella, keeping us and the drill dry :rolleyes:
good old TC masonry drill ground to a scraper edge ... flew through the spring steel, with plenty of rain water cooling from the full tins sat around on the bench
Simon was impressed ..... and overjoyed to have a second hole in a matter of minutes
left here for his brother's place to go finish re-assembling the little Deutz ..... should put an even bigger grin on his brother Richard's face .... was like an 82 year old Cheshire cat yesterday, looking at the two new M16 bolts protruding from the back of his little traccy's arse end :giggle::giggle:
Have known the pair of 'em since the late 70s and it's frightening just how fast the time goes by .. Si is starting to look old at 69, pushing 70 shortly ... and Richard has suddenly started to look his 82 years :( ..... old bugger still skis two or three times a year though, fair play to him.:cool:
all back together :giggle: .....
Richard ecstatic ... particularly after Simon explained the next option would have been removing the cab and take the top cover off the axle :oops: ... apparently he's very grateful for my efforts. We old timers gotta stick together :LOL:
gonna need a lorrawarmth to separate it again :giggle:
View attachment 52450 must've gotten a rain drop on the lens :mad: ... what you can't see is Simon stood holding the 4ft umbrella, keeping us and the drill dry :rolleyes:
Weather good here today
