Has it got a special play area of pedestrian barriers to stop the buckets escaping as well?
Of course. But that's on the compound 200m away so they don't mingle with the mud.
And were the Barriers photographed from numerous angles after they were put in place ?Of course. But that's on the compound 200m away so they don't mingle with the mud.
I always take pics leaving at night of barriers in place, arse coveringAnd were the Barriers photographed from numerous angles after they were put in place ?
Think that's all my phone contains pictures of, pics of how you left it, just in case.I always take pics leaving at night of barriers in place, arse covering
Do you use safetyculture app? it free for up to 10 users and quite adaptable for small buisiness use.We have tablets when working for some of the highway work so you can do all your risk assessments permit to dig and so on and save all your photos into one file along with the paperwork to send to the client
The full paid version is really good.
Just downloaded itDo you use safetyculture app? it free for up to 10 users and quite adaptable for small buisiness use.
just about anything is PDF-able with full Acrobat ... have used it for years to secure documents, etc.Just downloaded it and had a play definitely works perfectly on the ground. What does the form look like once management receive it. Could it be turned into a pdf to share copies of
Unless you unlock itjust about anything is PDF-able with full Acrobat ... have used it for years to secure documents, etc... totally secure when locked down
need a user and master password to do that thoughUnless you unlock it![]()
Cracking the password on acrobat is difficult, but removing it completely is easy.need a user and master password to do that though![]()
if you're the creator .. doubt it's particularly easy if you're the recipient ??Cracking the password on acrobat is difficult, but removing it completely is easy.
The only evidence it's been tampered with is 'no / different password'.
Only seconds needed to remove a password and any/all restrictions.if you're the creator .. doubt it's particularly easy if you're the recipient ??![]()
tha's cheatingOnly seconds needed to remove a password and any/all restrictions.
Ever had a PDF that told you, you didn't have permission to print it?
(you just need the right tool)
Is it still cheating if you can do it too?
