Which pins and bushes?
King post to boomWhich pins and bushes?
hell that bottom pin's in a bad way or is it machined like that ???
Machined like that hopefully hahahell that bottom pin's in a bad way or is it machined like that ???![]()
No problems thanks for checking !All I have left is side plates! Sorry
You’d be better trying to get another shim which is, for example 1.5mm rather than a shim that’s only 0.5mm to go with the 1.0mm shim you’ve gotWhere can you get shims that are less than 1mm ? Or am I worrying to much ? Main boom pivot I got a 1mm shim either side but still a little side to to side movement it has new bushings and new pin aswell
ClassGetting there slowly
Haha I miss that jigsaw puzzleClassif you nip back to the 3rd post in this thread this makes it more significant
Fantastic!!!Just buckets and panels to get done
