What have i done ! New project tb 216R
Y
yanmarb03
Y
yanmarb03
Where can you get shims that are less than 1mm ? Or am I worrying to much ? Main boom pivot I got a 1mm shim either side but still a little side to to side movement it has new bushings and new pin aswell
heritage machining
heritage machining
Can you take out them shim and get a 1.2 ect shim to suit I think dig bits do them ready cut I used loads on my 40 year old Kubota kh5
You’d be better trying to get another shim which is, for example 1.5mm rather than a shim that’s only 0.5mm to go with the 1.0mm shim you’ve got
certainly looking more like it should for sure .... well done Boyo (y) :cool:
