band saw saw a bit of action today .....first job was 68 mm of seamless
suds refused to pump ... and could not be arsed to pull the pipes off to prime it
opened the bore out to 18 .5 mm ....
then reamed it out to 3/4" .....I know i took a pic ... but weren't on't phone this evening when I down loaded em all
neither was the 7/8" cutter counter-boring it out to take the hardened 'top hat' boss, that was left in one piece in the pix yesterday, holding the oil seal in the output casing ??
trimmed it down to 67.5 mm ... as per requirement ...
and got a pic of the finished article .......... which has also disappeared ?????? FFS
Pressed the top hat boss into the new bush ...
and pressed them into the stub carrier ....
sweet fit and went together real nice ...
sussed a location for a grease nipple and stuck it back in the Ajax ...
centre drilled it, 4.5 mm for a grease port and then 10.4 mm for a 3/8" x 28 tap (BSG / 1/8" BSP) for a nipple
bugger!! out of pix again
