Hi Brendan,
Yes, the Spectra CR600 or the new Spectra CR700 magnetic detectors are in our opinion, the best value for money before you start climbing into the £1000+ models. But I wouldn't recommend buying anything cheaper than this.
I tend to say to customers that although you can often save some money opting for a mid-range laser over a premium brand it is not a good idea to buy really cheap magnetic detectors. The reason for this is that essentially the laser remains pretty isolated on its tripod in the middle of the site (so doesn't necessarily need to be an amazing specification),whereas the magnetic detector, depending on the age of the plant, has to take enormous vibrations. Many many years ago we did use to sell other brands of magnetic detector but now we only sell Spectra as they are so reliable.
One customer, in particular, bought a cheap detector somewhere else and on its first outing lost it in a gravel pit. He is now very happy with his Spectra model
For anyone who is not familiar with these models...
The beauty of the CR series is that they come with both a magnet pack (for use with plant) and a traditional measuring staff clamp. This then gives you the best of both worlds.
The Spectra CR700 expands upon the capabilities of the CR600 and adds an elevation / direct read facility found in many detectors now to show the mm / inch scale. e.g. 10mm- 8mm- 6mm - 4mm- 1mm - LEVEL etc...
You wouldn't use this when magnetised to the plant (just the ultra-bright up / down and level LED's) but is very useful when mounted to the staff.
Links to the Spectra CR600 & CR700 are below:
CR600:
Spectra Precision CR600 Magnetic Detector The Spectra CR600 Detector is ideal for contractors doing both site preparation and general construction. It can be either staff or machine mounted, making it ideal for a wide range of applications. Using the magnetic mount, the CR600 detector is easily...
www.laser-level.co.uk
CR700:
Red Pickup mm Detector 127mm Pickup Magnetic Staff Clamp Bright LED's Loud Sounder Anti-strobe Radio Link Alkaline Only Rating: IP67 Built Tough 3m Drop Test 3 Years Spectra Precision CR700 Magnetic & Staff Mounted Detector Purchase or Hire The Spectra CR700 is either...
Hope this helps
Best regards
Mark Roberts
Laser Levels Online
