grass got hit again yesterday morning ... can not believe the speed at which it is currently growing, considering it's not seen rain in a while, now
pam had a surprise whilst sorting one of her veggie boxes ......
one of the many pheasants that wander about the place, here had obviously decided it was a good place to nest ..... looked like a rat had had most of 'em .. clutch of eleven eggs - two left intact
last time I moved the Thwaites it sprang a leak in the steering dept. .....
as I'm likely to be heading out to Simon's brother's place in the near future, Raglan way ..
he's got me some new 45 gal. barrels, for burning bins - me old one is all but burgered, thought I'd better get the bolloed hose off and call into Fastfluids, the guys I use for pipes, etc. and get one made up, along with some 1/4" hoses for the Haner on lil' Jake
I've had the floor/footplate off it once before for a hose replacement job, but a considerable time ago ... was a hard fought battle with its securing bolts this time and new ones will be taking their stead
the gear lever, which clamps to a short stub stick, coming out the box, was a different matter ... 12.9 bolt through it clamping the stick - snapped the head off that, nut undid, but damned if I could shift the shank out of its hole, which is effectively a cotter in the clamp too .. had it moving on the stub stick, but could not get that cotter bolt out ...
so only one choice ..
marked it first for re-alignment, once I get the remnants off the stub stick
very annoying, but needs must .... footplate will not lift off without the stick removed, to give a clear tilt back for the plate
then spent an hour with the airline, blasting all the years of accumulated crud from virtually everywhere under there
would like to meet the tosser who's been at the wiring, prior to my ownership .... it really isn't hard to do a decent job
damned if I can see where the oil spray was coming from, but was doing at as steering, so has to be one of the pipes to/from the ram .. both looking ropey, so could well be a pair job.
was going to have them off today, in readiness for a Raglan foray, but the kids've been here for several hours.
Mañana job
... but might just run it up first to see exactly where the olio is coming from
23C here yesterday, sweating in the sunshine, in shirtsleeves ... 13C today, back to a fleece with overcast skies and a cold N. Easterly, blowing hard
not looking much better tomorrow either
