What oil do you have in it?Another interesting note it seems to be heat related ie it works better when cold
Pita?I have pulled the pump bit of a pita to get out next im going to strip and inpect it can't be that hard to refurbish can it?
Great stuff!A kit of parts all lapped using carborundum paste and a piece of glass
now all you have to do is re-time itA kit of parts all lapped using carborundum paste and a piece of glass
Proof in the pudding I suppose, if it drives it drives!I just put it together I can't see how it's timed the part I ground goes in first then the part with the pistons then the thin flat plate with the valve cutouts but that's keyed so it only goes one way
They’re not timedjust had recollections of Trax saying in CEF a long time ago that these things needed timing, but suppose if it's keyed, rather than splined it has to go back together right![]()
