Whats the best make for diamond blade for a stihl saw?
Y
yanmarb03
I bought a marchist one from sfix and it lasted a day have also tried spectrum can anyone recomend a longer lasting blade
bobthebuilder
this
Dart Red Ten MGP-10 300mm Diamond Blade for Cutting Concrete - 20mm Bore Size​
33 quid ,can fault it for the money cuts indian slabs with ease ,cut miles of them ,great value for money
As gunners said.
I've tried loads over the years and tbf doesn't seem a lot between them.
Currently hilti on 12" ox on 9" and Oxford on 4½"
Spectrum double 6 was a good blade, currently bought a red one from Toolstation was the cheapest one on there, I don't use mine often the blade looks ok but the 20mm bore is a very tight fit. If your going to be cutting a lot of metal better switching to a metal specific blade, not only cuts a lot quicker but last a surprising amount of time
Always swap to a metal unless odd cut. A lot quicker
The diamond blades can also snag In the cut causing chainsaw like kick back. Won't cut you but can give a sprain and a nasty bruise. Failing that they can get jammed in the cut and when yanked out pulls the diamond off the edge of the blade in chunks.
Had a metal blade shatter a few years ago on a 9 inch across the face so so lucky!
It is utterly beyond me why so many people take the guard off grinders. I hate it. And I really hate when other people take them off my grinders.
Guard was on had a face mask on all day as well as goggles took it off for dinner forgot to put it back on!
Canal Navvy
Canal Navvy
Guard off grinders is like one handing a chainsaw, sometimes necessary but not something to do routinely
Canal Navvy
Canal Navvy
Sorry should of added more detail I did a 4 metre long cut in 100mm concrete and it wore it out in one use
I only ever use the stihl for concrete slabs etc I have had marchist repointing blades in the past and they have been great
Was that with a good supply of water in the right place ?
Which way do people cut?
I always go forwards but have seen multiple videos of people cutting backwards
