Y
yanmarb03
Always forward for meWhich way do people cut?
I always go forwards but have seen multiple videos of people cutting backwards
Had the lever turned on about half way is more water better ?
I find too much clogs the bladeHad the lever turned on about half way is more water better ?
if it jams it's going away from you, not back at youWhich way do people cut?
There was definitely no dust my boots were soakedI always work on if you can see dust out the back of the back of the saw then it needs more water, the pump bottles can rarely achieve this.
Lot of £££ for a blade but think I'll give one a goIf you want to blow lots of money and get pretty much the best all round blade go for a Norton 4x4 explorer.. about £300 each but vvv good!!
Duro DPA/C Asphalt & Concrete Diamond Blade
DPA/C Concrete & Asphalt Diamond Blade. Duro DSBM Asphalt & Concrete Blade is a laser welded blade with a wide gullet design, 13mm conical segments and 3 deep draft segments for lower vibration levels and longer life. Fast cutting with a long life.www.sam-turner.co.uk
I use them 12” 14” then the same brand but different model for my 16” ts800
Jack
Must say I had a bad experience with Pulvex on some porcelain blades, they obliterated the tiles I sent at them. , he did give me a £200 credit which I need to spend thinking about it!Anyone got a good source/recommendations for 450mm dia blades for floorsaw?
I did send Pulvex an enquiry but heard nothing back.
Need tarmac blades for next job but will buy a couple of different blades to keep in stock.
Duros about half the price, have used these before and think they were fine but was years ago.
Duro 450DPA/C Concrete/Asphalt Blade
Duro 450DPAC ConcreteAsphalt Blade A laser welded blade with a wide gullet design, 13mm conical segments and 3 deep draft segments for lower vibration levels and longer life. Fast cutting with a long life.Suitable forIndian stoneClass A engineering brickClay productsAll reinforced conrete...www.powertoolsgb.co.uk![]()
Duro 450DUA/C Concrete/Asphalt/Metal/ Hard Materials Blade
Duro 450DUAC ConcreteAsphaltMetalHard Materials BladeA laser welded blade with key hole gullet design and 13mm conical segments for lower vibration levels and longer life. Incorporating the latest SDT spaced diamond placing technology. Very fast cutting with very long life.www.powertoolsgb.co.uk
What surprises me is these are all being advertised as tarmac and conc whereas I thought a different blade was needed for each material. The last blades I bought were either general purpose/hard concrete/abrasive (asphalt) but these were cheapo ones and lasted 5 minutes. I want something that will cut fast and last a bit too.
On table saw or stihl saw? 20mm porcelain?Must say I had a bad experience with Pulvex on some porcelain blades, they obliterated the tiles I sent at them. , he did give me a £200 credit which I need to spend thinking about it!
