been a busy-ish day ...... once Pam had departed, for Plymouth and Shem minding duties for the rest of the week, 'bout two o'clock
.... Home alone
... no interruptions 'til Sunday evening
Been getting me new Jabsco installed in the back end of the 'Drema
.... bit tight in places
- everywhere in fact
... bits of skin missing all over
.... especially when I had to make an ultra quick exit, from the engine bay, when I was joined in there by the Group Leader of 633 Squadron
...... bloody hornet must've been 60mm long
.... sounded more like a Dornier diesel, than a Wellington or Lanc.
..... bloody thing has been doing
fly bys all evening
started with a sort out of the tail for the tank ....
brass hose tail was a perfect fit over the swept hyd. hose tail and being brass was an ideal candidate for a soldering job ..... once I'd got the hose tail clean enough to get the tinman's to take to it and sweated on
installed that and then routed me new shiny bit of 1" fuel hose down into the engine bay, to where it needed to end up to meet the pump's outlet tail
next on the agenda was persuade the Jabsco into position to suss a fit .... took some wriggling in .....
although it doesn't look it in there ... 's a big lump in a small space ..... marked the best location
and dropped the belly plate ...... was hoping to find that red button ..... but no such luck
gave me a good chance to clean out the back end of the engine bay too while i had this belly plate off ... done the other two a long time ago ... on Zeus,s ... this 'un bolts on
...... don't think it'd ever been off
anyway, got yon plate back in position .... 4 hands would've been handy
.... and realised it was time for some grub .... this went down real well with a nice soft bread roll to accompany it .....
have had it before and REALLY rate it for a quicky .... bloody gorgeous
looks as good as the pic and tastes even better .....
so ... refueled, I set about persuading it all back in there again ..... after i'd checked out the control unit on 24 volts on the bench
the red button was as I suspected .... push to break .... and's wired in parallel with the float switch .... yon relay in the box full of rubber must be a latching unit
.... so needs to have a circuit 'made' in the normal position, which was a bit of a PITA
... but it got druidised and'll do for now 'til I can find a replacement guts for it ...... the floaty bit was working fine
it all went back in and got bolted down, followed by an introduction of said rubber bit .....
jeez it is tight to get yer mitts into, but got there .... routed and cable tied everything into place .......
In the middle of refitting the float switch and me phone rings ... Simon ... "
are you still up? " .....
silly Q.
yeh sat on the top of the 'Drema's fuel tank , re-fitting the float switch in it - it's only half nine FFS "
..... he wanted to drop by on his way home, with my laser target, he borrowed ... several years ago
that I'd asked him if I could 'borrow back' for a while
so by the time he'd arrived I'd gotten tidied up for tonight ..... and was on watering duties
... daren't let Pam's plants expire on my watch
.... been 28C here today
...... wiring to sort tomorrow and can give it a try
..... a good hour plus watering
... good job I tidied up when I did ... struggling to see the bloody plants, by the time I'd gotten around 'em all
beautiful semi-lunar eclipse tonight when the moon came up, 'bout ten o'clock
.... took about two plus hours to transition to the full moon we've got tonight
