The best loopholes for using dads tractor as a lorry. DVSA please don't look in here.
As said previously...... You get stopped. You get a ticket. You now have a choice.... Pay a fine or go to court.
The issue with where we are is large companies paying fines and giving remit to stupidity by proxy......
Always have your say in court if you believe your correct.
Not really happy with it , need to source some straps with delta ends to go over the rope hooks and try to find some with rave hooks that fit properly too.
When the digger is on I'm currently running the straps from a point at the front all the way to the back under the deck and up and over to get the required restraint without using any points that Ifor Williams have labeled as 500Kg max.
the restriction there is the degree you are prepared to distort the sides by pulling the rat sh1ts as tight as they ought to be :rolleyes::unsure:
Justme
Out of scope can become quite complicated. You really need a tm who specializes in that area rather than general transport.
Any vehicle can be run out of scope it's the work that dictates it.
True but for personal use exemption it stops at >7.5t
ahem..
There’s probably an exemption for that an all….
well actually ....
if there were no trailer lights fitted, then he wouldn't need them in the hours of daylight, but must give hand signals to following traffic....
as they are fitted they must work at all times.
as for the number plate, ....
unless it has changed, :unsure: as long as the drawing vehicle has a trace-able reg plate, the trailer doesn't necessarily have to have a matching plate, as long as the plate that is displayed is also trace-able to a vehicle in the same ownership (as the drawing vehicle - or can be traced to it) ...
it's possible this has been revoked with the advent of NPRC
Justme
My current understanding is that exemption only applies to agri registered tractors.
"Fixing of registration plates: works trucks, road rollers and agricultural machines 8.—(1) This regulation applies to works trucks, road rollers and agricultural machines. (2) A registration plate must be fixed on the vehicle in a vertical position or, where that is not possible, in a position as close to the vertical as is reasonably practicable— (a) on both sides of the vehicles, so that the characters of the mark are easily distinguishable from both sides of the vehicle, or (b) on the rear of the vehicle, so that the characters of the mark are easily distinguishable from behind the vehicle, or (c) where the vehicle is towing a trailer or trailers and the plate is not fixed on the sides of the vehicle, on the trailer or the rearmost trailer (as the case may be) so that the characters of the mark are easily distinguishable from behind the trailer. (3) Where the towing vehicle is an agricultural machine, a plate fixed on the trailer may, instead of displaying the registration mark of the towing vehicle, display the mark of any other agricultural machine kept by the keeper of the towing vehicle."
Siht the bed!! Blatantly stolen, chucked on the back by any machine they got started on a site and legged it!! Madness!!
In fairness the chaining would likely comply in court. It's against the headboard on both parts and chained to prevent rearward movement.
I'd actually be angrier if they had picked up load security and not the blatent piss taking
From the way it's worded I'd say someone's cottoned on to the piss taking. I've seen a steady stream of low loaders at cuerden lately and that's 20 mins from greater Manchesters patch.
Maybe finally the cleanup is coming.
Did anyone see this
Whats at Cuerden?
