The best loopholes for using dads tractor as a lorry. DVSA please don't look in here.
Just realised they are 4 strings not 6 so 3-400kg a bale and the tractor has 20 on and the land rover has the same.
And I got the tractors trailer capacity wrong. More like 15t capacity. 21t trailer weight less trailer and forklift
what land rover?? ... t'other is a 6 x 4 prime mover and a triple axle drag
It's this: 😂😂
well I'll be damned ... that first one was a deceptive pic ... thanks for the others ..... string 'em out to dry ... 3.5 behind it and same up front, max GW ... GTW 7t
“Off road use” 🙄
Exactly that - modern tractors can shift a lot more weight than they can legally move on the road (they are designed exclusively for off road use after all!).
There’s a local farmer with a big Valtra and massive tri-axle silage trailer that has been over a weighbridge at 66 tonnes - it’ll drag that across fields all day long.
used to have a firm called Gwent Weighing Systems, fairly local to me .. built, installed and tested weighbridges .. used to do a lot for them with the cranes ... testing days were the easiest, craning test weights on/off their truck/bridges. .. all self contained these days with hiab handling
Local farmer comes past us to a stock field , spanking new top of the range jcb Agri telehandler, trailer loaded up with all assortment of bales on , never a single strap over anything! Absolute no fecks given!
Last year I watched them loading out adjacent paddock after they baled it , never bothered to re attach brake lines/lights to trailer after they loaded it up in between loads, yet alone strap any bales on! Just idiots!
I followed a farmer the other day towing a 16ft ft double axle ifor behind his tractor, with 8 round silage bales on. 4800kg on the trailer I reckoned😬
I know Joe quite well, used to work for his uncle. He was running a 120hp mog towing an artic trailer on a dolly for a bit, but the trailer was so heavy it used to drag him backwards down hills he was trying to drive up. Hes a grafter, but a bit of a nutter with it.
In fairness I've had that happen several times towing the legal 3500kg behind a disco. Overun brakes on ifors are great untill your going uphill!
sounds to be beyond "nutter" .. wants locking up .... how would you like your family behind him when the tail was motivating the dog :mad::mad::mad: ... brakes obviously not working or a simple application'd have stopped said trailer ........wanker emoji.jpg ... pure and simple
absolutely -- over run only work with weight being exerted upon the coupling linearly forward
the nutter above should have had functioning coupled stoppers ... 's people like him need the book throwing at them and then locking up ... they all seem to think it's just a huge laugh - 'til they kill or injure some one 🤬🤬🤬🤬🤬
