Becoming somewhat of a signatureGood to see little fellas out there again keeping things safe![]()
2.2t to me i think!View attachment 43876
Question for the blokes that do this often as I forgot when the last time i repaired tarmac was ....12m long x 40cm wide and about 7/8 cm deep.
How much tarmac ....1 ton
Stop it ...I've ordered a ton !2.2t to me i think!
M3 not me bloody predictive text lolStop it ...I've ordered a ton !
Ooooh that sounds posh ....its getting 1 layer of 6mm gravel
Dont seem to do a lot of base coat over here.
I seeIts not being posh or even structural integrity. It's simply that over here base is considerably cheaper than topping.![]()
'nother holiday rental that most'll never be able to afford @Giles?Last bit of soil to tidy up and we are out of the curtilage of the building now just our little compound to clear and we are done
Over a year now on site
Looks to be a decent lump is that a tmk300 on a tb260 ?
Yes, and perfectly. If it’ll cut it it’ll handle it no problem.Looks to be a decent lump is that a tmk300 on a tb260 ?
If so how does the 6t handle it ?
Good to know ..I thought it might be a big lumpy on a 6tYes, and perfectly. If it’ll cut it it’ll handle it no problem.
Not on the mighty Takeuchi!Good to know ..I thought it might be a big lumpy on a 6t![]()
Totally! If Calsberg did counterweights they'd probably be called Takeuchi.Not on the mighty Takeuchi!
Probably be a bit tippy on a lesser yellow and grey machine though…
Takeuchi is the Japanese word for counterweight!Totally! If Calsberg did counterweights they'd probably be called Takeuchi.
Ours is not to reason why, just to do and ….. although lord tension been able to afford it lol'nother holiday rental that most'll never be able to afford @Giles?
we got one round here ...... cost an absolute fooooooortune .... got away with all sorts, on a grade one listed structure ('cos it was gonna need to be rented out) and costs a small fortune if you want to rent it ..... owned by ... landmark trustOurs is not to reason why, just to do and ….. although lord tension been able to afford it lol
Bit of white an shite will see you right... Black grease on the white white paint and frequent fire loading mean that you don't see the rust so much on mine, which is good.Fighting talk ......let's wait and see ! ...yellow could be the new red
Bit of yellow and grey every day
.......well at least the days im not swanning about on a motorbike
