Getting there that was flat Monday
It’s on the 5.5, had it on the bottom for strainers on 3 but 5.5 just carries it so much better and on joystick not foot control.Nice work. Would you not find it easier mounted from the bottom of the mast? I find this way I can get more height closer in- makes quite a difference- especially when on the 3 tonner.
You have a powertilt hitch don't you? What's your thoughts on using that with the knocker. Do you think the hitch would take the shock?It’s on the 5.5, had it on the bottom for strainers on 3 but 5.5 just carries it so much better and on joystick not foot control.
Can run on my own like this start post then jump in and bang away
pretty sure he outed the tilt hitch .... can't imagine 'em being keen on holding that beast in one spotYou have a powertilt hitch don't you? What's your thoughts on using that with the knocker. Do you think the hitch would take the shock?
Yeah reckon your right. It's bad enough just having that amount of weight hanging offset as it ispretty sure he outed the tilt hitch .... can't imagine 'em being keen on holding that beast in one spot![]()
Looks a well built thumbBit of a tidy up we’re we’ve been doing some drainage , another one to go in yet but scaffolds in the way, wants raking through with the rake bucket I lent @JD450A when we go over it at the end , harfords thumb grab is so handy always makes you wonder why you’d never had one !
Very well built and very happy with it , proper thick steel and excellent having it on the dipper pin ! Can see why everyone likes them !Looks a well built thumbgood that it works with the bucket pins too ...
You do get to work in some lovely places !Started a new footpath job today- about a 1km long of washed out path. Stump to move first![]()
Sold it to a lad to use with a tree shearYou have a powertilt hitch don't you? What's your thoughts on using that with the knocker. Do you think the hitch would take the shock?
doesn't surprise me in the slightest GilesLast bit of the 1400m2 of turf and last bit of fencing finally getting done, Cheated on septic fencing rather than doing 8 box strainers I used some jump poles to make 1 big box, battery chainsaw been ace for doing these.
Chucked a footing in for wall restore and built a quick pond before machines were excluded from that area by fencing and turf, busy day for 2 of us. Curiously more done than when 4 lol![]()
Just over a tonne + 30% wastageView attachment 43876
Question for the blokes that do this often as I forgot when the last time i repaired tarmac was ....12m long x 40cm wide and about 7/8 cm deep.
How much tarmac ....1 ton
Good to see little fellas out there again keeping things safeView attachment 43876
Ooooh that sounds posh ....its getting 1 layer of 6mm gravelJust over a tonne + 30% wastage
I would probably do 750 kg base
500kg topping
