diggerjones
On the plus side i bought a grading bucket for it at right money and that fits.
that looks to be fabricated, rather than forged like the old one (as far as I can see in the pix) ... so yeh - alter-able IMHDOSo bought a tipping link off flebe. Sold as kx61-3 and it probably is. But won't quite fit mine. Its maybe 20mm short and where the tipping ram fits (where the spanner is) its needs about 3mm each side chopping out to make ram fit.
Would it be possible to chop the bosses off and move them.
View attachment 41092View attachment 41093View attachment 41094View attachment 41095
see you have a leaf problem too DylanOn the plus side i bought a grading bucket for it at right money and that fits.View attachment 41102View attachment 41103View attachment 41104
IMHDO ? i never know what these things meanthat looks to be fabricated, rather than forged like the old one (as far as I can see in the pix) ... so yeh - alter-able IMHDO
The thing with adding a quick hitch is the extra build height takes away breakout force so you either keep pin centres close and lose power or open pin centres up a bit and lose either crowd or dump angle. Just bear in mind ur gonna lose dump angle if you lengthen links which might make digging the back of a hole nice and plumb awkward. Newer machines don't suffer as badly since quick hitches have become the norm as most manufacturers factor in a hitch being fitted.
in my humble Druid opinionIMHDO ? i never know what these things meanits bad enough with a 12 year old daughter
I'm now thinking its a plus altering it as i can get the crowd exactly how i want it. As like most stuff with quick hitches on you loose half the material when lifting boom high
That's odd. I have a wedgelock on both the 1.8t and 2.8t and the crowd is brilliant
Yeah think your right cos looking at this pic the crowd doesn't look vastly more than the pic Jonesy put up. Yet the bucket would retain far moreBut it’s the bucket shape and pin mounting that make it brilliant. Once you’ve got a QH fitted then you can’t mess around with pin spacing to alter geometry, it’s all down to the bucket after that.
Also depends if you've bought a hitch specifically for your machine or you might have bought a second hand hitch with the right pin spacing to fit your digger but actually for something elseYeah think your right cos looking at this pic the crowd doesn't look vastly more than the pic Jonesy put up. Yet the bucket would retain far more
