Kubota kx 61-3
The round bit is the seal, the two lips grip the edge of the door.
diggerjones
diggerjones
😂😂I'm not that thick ask monkeybuisnes. I mean the little hole in length of it. 😁👍
diggerjones
diggerjones
diggerjones
diggerjones
Its the seal that the top window slides on to the bottom window. As you can see theres a big gap. They had used a piece of pipe cut down the length and pushed on to bottom glass.
Hope you dont end up like me I bought a 2011 kx71 3300hrs off a mate about a year ago and to date its had
1 x Track motor
2 x bottom rollers
1 x top roller
1 x rocker gasket
Bucket ram
dipper ram
1 x Breaker pipe
Pair of new tracks and sprockets
I got it at a very good price esp in light of whats happened to plant prices but he certainly knew when to get shut 😁
Mine at 3500 needs all nee bottom rollers £125 each 3 each side ouch
diggerjones
diggerjones
Well finely found a quick hitch at the right money. Doesn't seem to have done a lot.
diggerjones
diggerjones
So bought a tipping link off flebe. Sold as kx61-3 and it probably is. But won't quite fit mine. Its maybe 20mm short and where the tipping ram fits (where the spanner is) its needs about 3mm each side chopping out to make ram fit.
Would it be possible to chop the bosses off and move them.
View attachment 41092View attachment 41093View attachment 41094View attachment 41095
Cut your losses and get proper one from ashtrak,Mst or l and s probably have one
Could it be there are different versions, as l&s also list this one
diggerjones
diggerjones
Your probably right. And Giles is probably right also.
This was only £80 delivered, so cheap enough to butcher. The other thing i was thinking was making it slightly longer as to make the geometry better on the curl of the bucket
