Ah k. Does it have a roller ?It fits but going 'flail first' the brambles bunch up and pull against the skids, flattening all the planted trees.
YesAh k. Does it have a roller ?
No, what I mean is that the motion of the big square lump that is the flail going into brambles twice it's height catches brambles and drags them on each side. these then trash the rows of saplings! If you go over it with wheels first it's much less of an issue as the wheels are 'pinning down' the lengths of brambles as the flail then goes over them. I barely have 4" clearance each side, they are tight rows.Could you swap roller and turn it round so flails are essentially spinning in the other direction. On tractor mounted flails they can run in either direction. One drags you in but leaves a good finish the other doesn't so much but leaves a worse finish.
Other thing is have you looked at different flail options. There might be a more vicious version.
The flail will eat whatever you put in it.
Not enough last minute maintenance as handbrake needs adjusting, couple of rubber brake hoses are worn and a rough wheel bearing……..followed by the alternator packing up on the Disco 1.Waiting at the MOT station after some last minute maintenance on the Iveco!
Only just had my iveco back yesterday 2 mot later after being messed around. Handbrake issue with mine tooNot enough last minute maintenance as handbrake needs adjusting, couple of rubber brake hoses are worn and a rough wheel bearing……..followed by the alternator packing up on the Disco 1.
My iveco was always a pita for handbrake cables and Anti Rollbar linkagesOnly just had my iveco back yesterday 2 mot later after being messed around. Handbrake issue with mine too
Handbrake on nearly every motMy iveco was always a pita for handbrake cables and Anti Rollbar linkages
I had one as a courtesy car from Land Rover, it was pretty quick as a EV, But it was a loud and uncomfortable ride for a 50k car, was glad to give it back!We test drove the evoke didn't like it, slow and not much room Mrs picked top of the line Nissan quashqai instead
I had to fold myself into the passenger seatI had one as a courtesy car from Land Rover, it was pretty quick as a EV, But it was a loud and uncomfortable ride for a 50k car, was glad to give it back!
There tomorrow to extend their yard
To be fair our big disco hasn’t the worlds most spacious interior, doors must be a ft thick! Super comfy and smooth when in it though! Leagues apart from the evokpukeI had to fold myself into the passenger seat
Anything made out of halewood is shite....To be fair our big disco hasn’t the worlds most spacious interior, doors must be a ft thick! Super comfy and smooth when in it though! Leagues apart from the evokpuke
I was similarly stuck a couple of weeks ago in a much deeper ditch than I expected - totally bellied out. A jcb telehandler wouldn’t touch it so I had to dig under from the sides and drag it out sideways. And yes, I know I need new tyres (struggling to find anything suitable in the UK though).Freed the beast. The mule was having none of it, just spun the tyres then snapped the strop. So I had to go for reinforcements.
Then I got stuck back in (and almost stuck again). Now I’m just switching rows when I get to something tricky and to hell with the tree that gets trashed as I switch. Plenty more there, I’ll call it thinning too waste
View attachment 40992View attachment 40993View attachment 40994View attachment 40995View attachment 40996View attachment 40997View attachment 40998
Why can’t you find anything suitable in the UK?I was similarly stuck a couple of weeks ago in a much deeper ditch than I expected - totally bellied out. A jcb telehandler wouldn’t touch it so I had to dig under from the sides and drag it out sideways. And yes, I know I need new tyres (struggling to find anything suitable in the UK though).
View attachment 40999View attachment 41000
