I made one for a pal of mine but used the dipper pin hole as the same pivot as the thumb and it tucks up tight to the dipper when not in use, going to make one for my little komatsu when I get some time and the machine is back in the yardThinking one of these would a handy piece of kit to have on the mini digger.
Any pro,s and con's. Or best prices. Does @CPS do them
Basically anyone who doesn't already have one fitted is a fool!Thinking one of these would a handy piece of kit to have on the mini digger.
I'm a foolBasically anyone who doesn't already have one fitted is a fool!
Thing is grabs are great for dedicated handling tasks as have the articulation of the bucket ram and if your into stacking timber all day then clearly a rotator is going to be more efficient too. But the thumb for what it cost £600-£1000 for a small machine, is there when you need it, always on the machine so no extra attachments to cart around, they work splendidly with the bucket and maybe it's just the type of work I do but I find I always need the bucket for digging stumps, rocks , raking brash, it just makes more sense to have the thumb to move it all around as I go along rather than swapping around with a grab all the time.I made one for a pal of mine but used the dipper pin hole as the same pivot as the thumb and it tucks up tight to the dipper when not in use, going to make one for my little komatsu when I get some time and the machine is back in the yard
very useful if you don’t have a dedicated grab![]()
Thanks...Basically anyone who doesn't already have one fitted is a fool!
YesThinking one of these would a handy piece of kit to have on the mini digger.
I`m only a partial fool, because mines not hydraulicBasically anyone who doesn't already have one fitted is a fool!
Could be quite easy to twist using that to handle rocks being quite wide?
I was a little concerned at first, but it has seemed to have been OK .Could be quite easy to twist using that to handle rocks being quite wide?
Hydraulic 1 for a TB016 im post bombingYeswhat size of machine?
1.5t case. Delivered to CheshireYeswhat size of machine?
Some people (and not suggesting for a moment you) manage to f**k up the installation of a thumb. I've useda few on customers machines that have been awful. Not closing properly against the dipper because they've messes up the spacings of the two brackets and the ram closes before the thumb is against the dipper etc Or not meeting up with the bucket properly..1.5t case. Delivered to Cheshire View attachment 39707
