Lifton/Neuson 1001 Dumper won’t move …
F
Fishy
A
alec
Hi i'm Dougie im new to the group. I have a lift ton 750 highlift dumper will run about no problem when cold. When it warms up it wont go up hills or through soft ground everything else is working. Any help appreciated its a year 2000
How old is the hydraulic oil?
sounds like another one on here, won't go uphill :unsure:
A
alec
What pump is the drive pump lifton 750 highlift big pump or the smaller one attached to it? Help appreciated
Floor plate up take some pictures I will arrow it all for you!! Guessing when the oil was changed the tank cap o ring is in place?
A
alec
Cap O ring is in place
The small pump with the red end is a gear pump, (steering/tip) and the big lump behind it is the hydrostatic pump which on this dumper is mechanically operated drive (forward/reverse!):Slowing when hot could be a worn pump!
