Forward backward wacker
Belle rpc 30/40 won’t go backwards
Have I seen you guys discussing fluid in handle levels affecting this?
Cheers
No Oil under engine, but handle appears to be on the underside not above.
Should this undo? Had 20 odd stone on strong arm after big DEWALT 1/2 rattle gun refused tried both ways.
Swapped handle right way, drained all water out water trap, knocked a ton of dust out filter poor thing had coffee cup of fine dust in it. Ordered new one but take a few days.
use a T bar to apply serious pressure with handle properly supported and give the top of the tee bar a couple of good whacks with a decent knockometer ... should shock it enough to break the stiction ... I'd be guessing that's the fill point
It’s had the big DEWALT rattle gun on it shaking it will get Scaff bar and dead blow hammer on it
use a proper lump on it .. copper head'll not give the same shock
Cheers gents will try all these Monday
I think it’s 32 grade hydraulic oil
Got it undone, hot day and 5 foot snap on breaker bar. Filled it up but can hear it leaking out down by plate when you activate handle without it running.
So guess I’m taking it apart see what’s going on in the inards
