Will check tomorrowAre there any oil leaks from the underneath onto the plate?
The big nut you can't undo. You could try a real good clean hit with a hammer flat on the face of the nut to shock it. It'll be the same as the hyd tank cap on the takis it'll be kin tight over time.Where do I top fluid up?
use a T bar to apply serious pressure with handle properly supported and give the top of the tee bar a couple of good whacks with a decent knockometer ... should shock it enough to break the stiction ... I'd be guessing that's the fill pointShould this undo? Had 20 odd stone on strong arm after big DEWALT 1/2 rattle gun refused tried both ways.
Swapped handle right way, drained all water out water trap, knocked a ton of dust out filter poor thing had coffee cup of fine dust in it. Ordered new one but take a few days.
use a proper lump on it .. copper head'll not give the same shockIt’s had the big DEWALT rattle gun on it shaking it will get Scaff bar anddead blow hammeron it
like you're gonna be fit for anything Monday????Cheers gents will try all theseMonday
I think it’s 32 grade hydraulic oil
Sounds like a medieval torture techniqueBoil the kettle, pour the water on the body then try undoing it![]()
