It was cheap, that's all I can say. 🤣
Plan is give it a tidy up as it was stood for 3 years, then it'll be ready for a new owner.
It's not the tidiest but if I get most things right on it then It'll be good for someone who wants abit of summer fun.
....hopefully a quick project....unlike the rest of my projects 🤣🤣
looks square enough ... if we EVER get any soft top weather it ought to turn a shilling or two :giggle:(y)
always fancied an MGRV8 ... were cheap enough back in the noughties ... and 99% were clean as a whistle as were never sold into the home market and had to be brought back to blighty from warmer climes
only draw back with them was the 3.9 lump - hand grenade with the pin out -
if they'd only put the 4 litre into 'em, with the 'banana' manifold out o' the P38 :(
a friend had one and was all the original should've been ....... and wasn't
most of 'em went to Japan, so were conveniently RHDs
maz
maz
sounds like a plan :giggle: ... bas***ds
Our Hermes bloke is brilliant, although he's blotted his copy book yesterday :LOL: when he didn't show with the delivery they'd said would be latest 3rd June ... I'll give him some stick when he turns up :ROFLMAO::ROFLMAO: ... didn't expect to see him TBH ... wishful thinking on Hermes part FFS !!
the rings're rolled up on my old DS&G lathe ... make a mandrel for the chuck and roll 20ft of 12mm bar round it slooowly off a rest ... the Harrison'll do the same - plenty of grunt - just won't be able to feed 20ft lengths into it, as it doesn't have a 60ft wide workshop behind it :ROFLMAO: could drill some holes in the box walls and thread it through :LOL: ... take some lining up though :oops::unsure:
You lost me there, had to do some googling :ROFLMAO:
So like this?
Would have thought that rod was too thick for rolling that easy, mighty impressed though!
So like this?
very similar .. I used to put a hooked tag on the mandrel to catch the start tail in ... then wind :giggle: .... have rolled 12mm square and 16mm round ... need to have the mandrel slightly smaller than the desired size as there was always 'spring back' ...IIRC to get the 4" OD in 12mm it needed a 2 3/4" mandrel ... might still have a small one - will get you a pic
  • Like
Reactions: maz
you're in luck ... just been and had a shufty and .....
old hydraulic cylinder rod
12mm square
12mm round and square ... thought I had a few coils left, tucked away .... the advent of thin discs made lopping them up a doddle :giggle::cool:
and as a bonus ..... me sheet is drying nicely ... with its French chalk lines re-appearing miraculously :cool: ... 'nother hour and I might go fire the genny up and put the plasma through it :giggle:
maz
maz
12mm square
View attachment 36234View attachment 36231
Nice one, that looks a lot simpler than I thought.
I'd try it on my wee Kerry but I might be limited to the thickness of fencing wire :p
Well it dried up enough :giggle: .......... so dragged the plasma out, wound up the compressor a bit, drained it down and then let it have its head..... plugged the plasma in and wound the genny up :)(y) .... after i'd gotten the sheet all set up with a straight edge...
and some support for the piece coming off ;) ..... and off it came
spun it around for the 2 m cut .... didn't have anything I trusted that length to hand, so did it in two
was then just a case of trimming the rest down to appropriate sizes to suit their eventual home .....
wish I'd remembered to polish the edge of the edge off first -- snagged it and notched the cut :mad:
pile of bits ready for tidying and assembling into a workbench
didn't see any point in wasting this bit by trimming it straight through .... will make a nice setting out square with some careful fettling
top is sat on the bench awaiting my attention and all little the bits're tucked up for the night in a box
lop up the 502 box next for the support structure ..... but looking at the weather forecast it ain't likely to be before Tuesday :(
............ and then Clara arrived feeling much more herself ....... been to a 'party' down the village ....
...........and proceeded to issue instructions as to what we were going to be doing next (after I'd had ten to tidy up):rolleyes: .....
saved by Pam's Jubilee 'Crowns & Corgis' indoor Barby tea shortly after :giggle:
... nice it was too ...... pity it was too bloody cold to have had the tea we had planned on the patio :rolleyes::( .....
one to make you smile ......
you will NEVER, EVER see me with a corgi on my forehead again :ROFLMAO::ROFLMAO::ROFLMAO:
still, it could've pissed down for the entire day:mad: ...'tis June, after all :unsure:😭 12C's warmer than the 10C we had earlier in the week🥶
L
LKSF
Pennine Hillbilly
After I complained the Yodel guy turned up at 7pm with the parcels :ROFLMAO:
DSG, the Rolls Royce of lathes, made just down the road from me too. I never knew you could make rings like that on one. My old Harrison being offloaded and into the garage until the workshop is built:
Made in Yorkshire too (y)
L
LKSF
Pennine Hillbilly
That sounds ominous lol
It's their famous failure, something (I forget what, piston rings, valve stem oil seals or something) gives up prematurely, the cat gets blocked and the engine dies. That aside they were good cars and many had their engines replaced by the better Celica one by owners.
That's going by memory, Google will know better, but it's something like that, definitely a blocked primary cat.
Makes some sense as I was told it had, had a new 2nd hand engine. Its got a bit of vvti rattle, but that's improved no end after me running it for last 3 days. It was stood for 3 years and the 2 years prior was less than 200miles
Nice lathes the 140s ... had a 165 for a while and that was lovely, but a bit small and replaced it with a Mastiff ... the type 17 ran alongside it for a long time 'til i got bid absolutely silly money for the Mastiff and it went :giggle: .... have had all sorts over the years .. one I probably recall most 'fondly' was my Holbrook Model C 10 ... that was superb
