sandbags89
neither of those sound pretty
are there ways to determine whether either of these are the case?
been sent this diagram that shows a couple relays that could affect starting... how would i test a relay to know if its doing its job?
it also shows the slow-blow fuse on this diagram that i mentioned previously.. unfortunately it does not show the actual locations in regards to where it is on the machine. My manual seemed to give me the wrong location for the slow-blow fuse strangely, but it lists it as a cause for non-starting in the troubleshooting section. need to find that effing thing!
Does it have to be beer glass? Is a wine glass not as effective??
unfortunately they put this thing together i don't think i can get to the starter to remove it.I think as you said the engine was running poorly, maybe starter isn't the issue. But if you do decide it's worth a look it's not to difficult to remove, strip down and clean. Check to see if brushes have worn. This video is helpful. Sorry it's in Dutch!
Nogoing back to the relays... if one of these were thought to be faulty, would this simulate the "heavy breathing"?
was having a look at these just now and i'm not sure how to test these. Example of one of them below and the meter i have:
I personally favour the squirt into the empty injector ports ... you know it's going where you want it to be ...Ok good job, it has lots of crankcase pressure, hence the smoke from rocker area, valves and rockers all working well, have you got an oil can? It’s looking like piston rings and or bores, in its present condition, squirt some oil down the inlet manifold, only a small amount as we don’t want bent rods as well! It may raise the compression enough to start! If so it’s engine out to get the sump off!
least he could get at the starter thenOk good job, it has lots of crankcase pressure, hence the smoke from rocker area, valves and rockers all working well, have you got an oil can? It’s looking like piston rings and or bores, in its present condition, squirt some oil down the inlet manifold, only a small amount as we don’t want bent rods as well! It may raise the compression enough to start! If so it’s engine out to get the sump off!
you bad man MB .... the man's in La Sud de France FFS .... bet it's 'kin warm there this morning ..... better than our paltry 12CIt’s the white sock/sandal combo I reckon - your digger has potentially lost all respect for you sadly…
Best take his socks off then!you bad man MB .... the man's in La Sud de France FFS .... bet it's 'kin warm there this morning ..... better than our paltry 12C
Maybe easy start is why it’s like it is! And then the can ran outIt does look like quite a lot of exhaust gas escaping from somewhere near the pushrods... The engine is cold though so maybe once up to temperature would seal up a bit better? I would have thought that you could at least get it started with a good squirt of easy start as the engine is turning over. Getting the engine running would reveal more, if it's possible!
Bent valve, jump in timing
Yes your probably right! Dont use easy start... but it would be very helpful to see the engine running.Maybe easy start is why it’s like it is! And then the can ran out
I agree a running 1 and a half cylinder Smokey engine is better than not at allYes your probably right! Dont use easy start... but it would be very helpful to see the engine running.
bitch indeed. Taken off all the panels that are removeable. But that back yellow part of the machine is part of the chassis. Awfully inconvenient.No
exhaust /starter looks a bitch
I don't have an oil can, just a bottle of engine oil i used before. pour oil into the inlet I had my hand over before?Ok good job, it has lots of crankcase pressure, hence the smoke from rocker area, valves and rockers all working well, have you got an oil can? It’s looking like piston rings and or bores, in its present condition, squirt some oil down the inlet manifold, only a small amount as we don’t want bent rods as well! It may raise the compression enough to start! If so it’s engine out to get the sump off!
quite possiblyIt’s the white sock/sandal combo I reckon - your digger has potentially lost all respect for you sadly…
yea maybe more confident with this instead, like i did before. How much is little bit....cap of oil in each injector, or half..?I personally favour the squirt into the empty injector ports ... you know it's going where you want it to be ...
yea I wish i could mate, but literally haven't got it to start in months since I managed to move it and park it up there. Hasn't budged since.It does look like quite a lot of exhaust gas escaping from somewhere near the pushrods... The engine is cold though so maybe once up to temperature would seal up a bit better? I would have thought that you could at least get it started with a good squirt of easy start as the engine is turning over. Getting the engine running would reveal more, if it's possible!
well i've never had to use easy start on it before. I've only tried it once recently to try start it, and the engineer that came down also gave some squirts to attempt to get her going.Maybe easy start is why it’s like it is! And then the can ran out
Yes. That is, I know they are working plugs. They are new, and I also tested them on a battery, and they glow up red.Can’t remember if you said the glow plugs work?
Ok take a bit of w electrical wire, long enough to reach the battery positive and one glow plug, twist the wire around the thread on the top of the glow plug, tip half a cap of oil in the manifold, put the wire on the battery pos for 20 seconds, hand over inlet, try and start!
Send vid
