Yep this happened
Left hooker
Left hooker
Bucket ram on my zx180
K
Komatsu
😱heard again recently there rams were snapping, take it everyone is ok
Left hooker
Left hooker
this ram was re-rodded at 6 months old under warranty as due to leaking from scoring from damaged bush in cap done 7 1/2 years
stress point where the shoulder is machined :( .... not a great deal one can do to relieve it either .... Vee it and it weakens it further ... cut a shallow rad in the transition point is about the best that can be done , but again reduces the material diameter ....they take a LOT of hammer :rolleyes:
Left hooker
Left hooker
went right on last cut of the thread before shoulder can see the different times it has been letting go
can believe that Stu ..... yet another stress point and the smallest diameter of the component ;)
Left hooker
Left hooker
Hitachi sent through the tourqe setting for piston 4000nm :eek: can only get near half that with torque multiplier
no wonder the bugger snapped off :eek::eek::eek: .... insane figure :rolleyes::unsure:
They must have an extra Zero on that number, surely? I can’t see why it needs to be so tight?
Does the nut have a locking tab or pin?
I hope we're not getting mixed up between nm and lbs/ft. :unsure:
Left hooker
Left hooker
Well took all day to build up and put back on digger hardest part was holding down the rod to stop it lifting when tourqing up resorted in having to put a load on lorry (12t as lorry got built in weigher) and backing it up over the rod as when lorry was empty it was lifting
broke the small tourqe multiplier 3/4 drive that was 5:1 and made around 2600nm before letting go so borrowed a bigger one from another plant hire firm up the road and got it to the required 4000nm it was rated at 4800nm and 1:68
