this ram was re-rodded at 6 months old under warranty as due to leaking from scoring from damaged bush in cap done 7 1/2 yearsheard again recently there rams were snapping, take it everyone is ok
went right on last cut of the thread before shoulder can see the different times it has been letting gostress point where the shoulder is machined.... not a great deal one can do to relieve it either .... Vee it and it weakens it further ... cut a shallow rad in the transition point is about the best that can be done , but again reduces the material diameter ....they take a LOT of hammer
can believe that Stu ..... yet another stress point and the smallest diameter of the componentwent right on last cut of the thread before shoulder can see the different times it has been letting go
Hitachi sent through the tourqe setting for piston 4000nmcan only get near half that with torque multiplier
I may have the gear to go up to that If you require.Hitachi sent through the tourqe setting for piston 4000nmcan only get near half that with torque multiplier
nope lbs/ft is 2945 lolI hope we're not getting mixed up between nm and lbs/ft.![]()
