Whites quick hitches and buckets
This is the best solution I've seen for the hitch bar on a micro. Pic curtesy of Ollie Kitchen from his trip to Sweden in 2019. Something I must do myself in the future. They really are ahead of us with this stuff.
You can't expect too much from a manual spring hitch tbh unless there's a spring in there so strong you'd need a bar 8ft long. The thing with hydraulic hitches and harford manual wedgelock they don't just hold the rear pin, they also push the bucket back and keep the front pin tight against the back of the jaw.
To be fair the spring on my whites is strong, it does take a fair bit of force to open and you can't flick the bucket up to lock it in, you have to lever it open
My old Miller spring hitch used to need the bar rather than flick bucket to click it in. Little dab of grease underneath jaw used to sort that though.
Could be designed in to need the bar to fit the bucket to encourage putting the pin in while you're there mind.
Grahams
Grahams
I have a couple of manual S type hitches on adapters and dipper extensions. They are basically the same design as the hydraulic ones, but you manually do the work the ram usually does. They don’t seem to have any wear, but admittedly not a lot of time working. I don’t see they should wear any different than the hydraulic ones that don’t seem to wear at all.
Jimoz
Ditto on my mans. Around 2 years old
I had a whites hitch on a brand new kx015... what a pile of poops!!! It was near impossible to pick a bucket it up with it, it was all wrong in every thought possible!
The smallest bucket can be a pain to get on, if the leading edges of the hitch were just rounded off a bit, I reckon would make life a little easier to get them on.
Nearly every hitch manufacturer could do with doing that tbh. Its ok if you are working on a perfectly flat level bit of ground but that's rare most places.
Our S Type hitches have a constant force on them, both manual and hydraulic! I reckon we could build one on the same principle with a pin grab type manual semi quick hitch.
So who wants to try the proto type out? :unsure:
Are you talking about, basically, an S type hitch but with pin dimensions of a standard pick-up?
Basically an S type hitch sits down into the bracket, it wouldn't be possible to do this on a standard bucket.
Plus your S type hitch generally has a flat bottom, alot of standard buckets have a "hump" on top were the bracket sits.
Yes I can see what you mean. But in theory if the brackets were on a flat plate, so no hump in the middle and the brackets were a suitable shape, then it would be possible?
