What's the best micro ? price , additional services , can hydraulic hitch be fitted , servo controls .
not interested in Chinese ones .
What about the 2 kubotas ?Best micro I have driven is the Case 1.3t..... An absolute weapon of a thing and would hold it's own with an old-style 1.5 tonner. As said not really a micro anymore.
I still rate my 108 Takeuchi's (we now have two) as the best non servo micros...... Closely followed by the JCB 8010/8008.
Sany is £12,000 and a reasonable offering.
TBH doosan/bobcat is still likely the best true micro.
I've not come across a Kubota micro locally since the K008 in the early 2000's. Steve Trott rated his but they aren't for me.What about the 2 kubotas ?
U10 and kx08 the u 10 looks like a good option and im very happy with my kx027-4I've not come across a Kubota micro locally since the K008 in the early 2000's. Steve Trott rated his but they aren't for me.
Did you cut your buckets or buy new ones? I’d like to go S30 but I’d need to talk my neighbour into doing his Kubota as wellStill the e10 if you need to get through 710mm gaps.
S30 helps with geometry.
It’s not JUST the width, it’s the approach angle. Most garden gates are 800mm but things like outside taps/drains/boiler flues can all eat into that margin, and when tucked in to 710 wide the machine tracks are still about 1200 long so any sort of corners or angles compromise things.Where are yous working where you can’t get in at 760mm ?
I’d struggle to find a gate that narrow , come to think of it I’d be likely stuck before the machine
My yanmar sv08 goes down to 680mm and I've done plenty of jobs where a 700 or even 690mm machine would have left me stood in the road looking very sad indeedWhere are yous working where you can’t get in at 760mm ?
You are in Scotland, try working anywhere in the south of England!!Where are yous working where you can’t get in wat 760mm ?
