Don't know about your equivalent of our dvsa, but they take a dim view of adblue deletes/emulators over here. https://www.gov.uk/government/news/lorry-emissions-checks-to-start-at-the-roadside
I'm sure they do here too - I've got no desire to cheat and I dont mind the cost of adblue - but the system has to work reliably at a price a working man can afford unless people are going to do what they have to.Don't know about your equivalent of our dvsa, but they take a dim view of adblue deletes/emulators over here. https://www.gov.uk/government/news/lorry-emissions-checks-to-start-at-the-roadside
That bloody AdBlu crystallises, has it been recovering the fluid when you switch it off, @Furniss ?
that's more like what i meant James .... must block any orifices in the plumbing ... corroded was the wrong wordcould even be a fitting corroded up![]()
looks a right sack of worms .... so glad I don't have to deal with this new fangled crapThanks for the help so far fellas
Took the top off the pump housing this morning and saw some suspicious looking crystallization as per photo, underneath the area looked gunked up too,and when you start truck up adblue is weeping from a stressed/crack in th plastic at the bottom highlighted in photo.
So that was easy enough to diagnose, why the spanner down at the garage could do a physical inspection to back up what his laptop said feck knows
Next job will be to see if the part is replaceable without buying the whole pump because it looks like it screws on as it a torque guide on the part that is leaking ? and whether the truck will run without it well enough to get my kit from the job we are on to the next where we will be for a week and then can work while it gets mended ?
The second picture looks like the main filter housing, sometimes they are super tight when undoing them, perhaps its been stressed in the past, so you would like to think it should be available separately.
re the garage staff, it seems the same with any `hands on` job, a ever decreasing pool of top men and women who can do their job, and are good at it. You may of found one not in that pool.
The filter has a low torque setting stamped on them about 15nm or something? but you can end up using a 1/2 drive breaker bar to undo them.Thanks for the reply....... I have zero experience of adblue systems but now you point it out it looks like it may be the bottom of a filter and screw off hence the nut and torque number on the bottom
I have contacted a company called alliance electronics - that refurb pumps ,(dont know who else to try ) hopefully they might be able to supply the damaged part separately - would be a brilliant result after being quoted 1900€
In the meantime I have disconnected the wires to this part of the pump so it doesn't empty the contents of the adblue tank all over the road and done few kms test drive, after 5minutes it realised what was going on and went into reduced power mode ..... bit gutless but it only needs to get a mini digger and dumper to our next job tomorrow on pretty flat roads and we are golden.
After the endless s**t weather we really need to keep going for all sorts of reasons.
A neighbour runs a fleet of trucks and he uses alliance electronics to repair components for him, and recommended them to me when I was having a problem with one of mine, with a dash board display problem, as if happened I found a bad connection in the can bus wiring.
look a lot like the klik fits that were on the Golf's fuel pump end of last year ... squeeze the tag and pull gently to disconnect ... got an O ring seal in 'emBit of an update on the adblue problem - the new filter housing came this morning - ordered monday lunchtime from Alliance Electronicspretty impressive service - going to fit it tomorrow morning hopefully get the little truck out of limp mode - bit of a steady job trailing the plant about as is.
Anything I should know about the pipe fittings underneath - just so I dont bugger anything
View attachment 11340View attachment 11342
