Volvo 271 mini digger.
G
Graham
G
Graham
looks like your rotary coupling taking oil to the tracks and blade with presumably return circuits/second services also
follow the hoses from the offset ram to the change over valve - should be the easiest to follow
G
Graham
I think we may have found it under the seat. Seems to have 6 pipes and a solonoid on it. Think we might be getting somewhere Chaps 👍👍
Sounds like you have found it👍
It may have an override button on the end of the solenoid that you can push with a small screwdriver
In that picture top and bottom live or earth, the one to the side don’t use a that
If that is a 6 port valve, there must be another solenoid opposite that one to drag or push in the opposite direction!
G
Graham
Too dark to work now guys will start again in the morning. Will read through all your replies over a beer and restart in the the morning 👍thanks for all your input so far
not if it's a 6x2 diverter Mick .....
one set of ports will be default (say C + D) and the other set will be when actuated (say E + F) ..
twin solenoids'd be a Cetop double acting valve ;)
6x 2 diverters
3 x 1 diverter
cetop
G
Graham
Thanks guys, I’ll clean the crud off in the morning and try to take some better pictures. Theres 24 years worth of oil grease and mud in there.
