Yes the fat brown and the black are permanently live wether ignition is on or offHave to agree - something NQR.
Just a sanity check - the fat brown wire (to B+) is live at all times?
No. Just grounds through the mounts bolted to the block.Does an alternator normally have an earth wire to it ?
So the brown wire with yellow stripe shouldn’t be an earth at all ?No. Just grounds through the mounts bolted to the block.
I still think it is the exciter wire. It will read as negative until it has been excited and voltage exceeds the battery which makes the light on the dash go out and triggers the tach to start clocking hours. As said above the warning light in the dash needs to be working to trigger it to start charging unless you trigger it manually.So the brown wire with yellow stripe shouldn’t be an earth at all ?
As far as the wiring is concerned will ignition on be the same state as engine running ? Should the brown and yellow wire give 12v feed with just ignition on and engine running ? I’m asking as I haven’t checked it with engine running I’ve assumed gnition on is the same state ?I still think it is the exciter wire. It will read as negative until it has been excited and voltage exceeds the battery which makes the light on the dash go out and triggers the tach to start clocking hours. As said above the warning light in the dash needs to be working to trigger it to start charging unless you trigger it manually.
nope - alternator is not running/producing chargeAs far as the wiring is concerned will ignition on be the same state as engine running ? Should the brown and yellow wire give 12v feed with just ignition on and engine running ? I’m asking as I haven’t checked it with engine running I’ve assumed gnition on is the same state ?
The "W" terminal should have nothing on it when the engine is stopped.Should the brown and yellow wire give 12v feed with just ignition on and engine running ?
I think the clock works with just ignition on . I noticed it ticking with ignition on when I was looking at back of switch, the rpm is a drive from transmissionThe "W" terminal should have nothing on it when the engine is stopped.
With the engine running, it should have AC with a Rev dependent frequency (to provide something for the Tacho to work with)
it willI think the clock works with just ignition on . I noticed it ticking with ignition on when I was looking at back of switch, the rpm is a drive from transmission
Will check tonightDoes the charging light come on? Or is the bulb blown?
For the hour meter, yes indeed. (don't know why it's usually done like that - if it were wired to the oil pressure switch, the clock would only count 'engine running hours", not 'ignition on' hours)I think the clock works with just ignition on . I noticed it ticking with ignition on when I was looking at back of switch, the rpm is a drive from transmission
certainly looks like the brown/yellow goes to the alternator - via a diode --- what the hell is a battery temp switch???
