They don’t normally drain unless you take the hoses off! Its possible the cooler has retained most of its oil.
That sounds like the most likely explanation Mick . I’ve highly likely over filled it now . I expect that the dipstick is correct and that the cooler hasn’t let go off it’s oil when I drained it and the dim light on the dash is probably down to a fecked pressure sensor switch.They don’t normally drain unless you take the hoses off! Its possible the cooler has retained most of its oil.
The lower black part is quite loosely seated it looks like it also has a bit of fine wire around it. Maybe the connector onto the sensor is not in good shape .Yes it should have a red top under the black plug, and getting back to the oil, if the cooler is empty also then there should be around 18ltrs.
Both take 18.5 l apparentlyWhat transmission does it have? I’m sure they had two options of manual or shuttle.. which Id assume would give two different oil levels
Sorry for jumping in hereThat sounds like the most likely explanation Mick . I’ve highly likely over filled it now . I expect that the dipstick is correct and that the cooler hasn’t let go off it’s oil when I drained it and the dim light on the dash is probably down to a fecked pressure sensor switch.
