7 years I’ve had an E27 and I only just realised you could open the whole half of the side window from the back…
It has to be tidy- this is coppice work for relaying a hedge in future. Client wants it traditional. Chamfered edges etc.Buy @Furniss TMK. You can grub a lot of that crap out at ground level and it’ll regen again no problem.
Nowhere near as tidy as a chainsaw but you’d do a lot of that job in one pass.
No, it won’t touch that diameter. If you are initially ragging stuff out with the grab without cutting it it’ll do a better job though, and leave you with less contaminated finishing cuts to make.It has to be tidy- this is coppice work for relaying a hedge in future. Client wants it traditional. Chamfered edges etc.
They are spending probably £3m on the house rebuild so this is small beer
Plus- I’m burying an 18” bar and often needing the 28”. Surely a tree shear won’t do that kind of stuff?
the contamination is in the stump, where things like flints have been pushed up as they grow. How would a tree shear help?No, it won’t touch that diameter. If you are initially ragging stuff out with the grab without cutting it it’ll do a better job though, and leave you with less contaminated finishing cuts to make.
Anything it can shear you won’t have to return to with a saw.The
Now I see why you have a grinderI have a feeling I’ll be spending most of today changing chains…
And probably making some more!View attachment 85357View attachment 85358View attachment 85359
I used the grinder today on a few chains I’d rocked pretty bad. Made light work of it tbf.Now I see why you have a grinder
Stihl about to launch on the job grinder actually looks pretty good. Be interesting to see it in the flesh.
It happens7 years I’ve had an E27 and I only just realised you could open the whole half of the side window from the back…
