Just more of this while its dry
With a bit of that onbetween
Do you cap your whole drainage field with stone ?View attachment 85166View attachment 851675View attachment 85168View attachment 85169
View attachment 85170View attachment 85171
only if they invent a wood welder!Nice do a upper for @V8Druid there
I'm not a bad chipyy TBH but that is more work than I have life expectancyonly if they invent a wood welder!
no its just left like that till inspected and signed off - then leveled off with top of pipe and geotextile before soilDo you cap your whole drainage field with stone ?
Flail not better? I hate clearing up arisings...I’m getting out all the rarely used kit on this job. First the hedgecutter now the leveller. Ideal tool for the job.
I’m really liking the new grab too. Makes clearing up very easy, you can bunch it up like you can with the digger as well as take forwards or backwards.
The hedgecutter is seeing some savage use. Stopping fairly frequently to replace blades 🫣View attachment 85173View attachment 85174View attachment 85175View attachment 85176View attachment 85177View attachment 85178View attachment 85179View attachment 85180
he with the most kit winsI’m getting out all the rarely used kit on this job. First the hedgecutter now the leveller. Ideal tool for the job.
are those blades the right way up ? surely that would force them away from the fingers and snap them ?I’m getting out all the rarely used kit on this job. First the hedgecutter now the leveller. Ideal tool for the job.
Fair enough....maybe you need a bigger tractor and mcconellHow long do you think you’d be trying to flail this lot??View attachment 85181View attachment 85182
The reason these hedges are so bad is because they are the bits the local farmer with his flail can’t reach.Fair enough....maybe you need a bigger tractor and mcconell![]()
They alternated up and down from new, I just replaced as they were.are those blades the right way up ? surely that would force them away from the fingers and snap them ?
Wacker plates have a similar tendency.Anyone else think Vibrating rollers are designed to kill themselvesView attachment 85204
vibration is the greatest enemy of anything mechanical![]()
