Just more of this while its dry 🤷‍♂️
With a bit of that onbetween
I’m getting out all the rarely used kit on this job. First the hedgecutter now the leveller. Ideal tool for the job.
I’m really liking the new grab too. Makes clearing up very easy, you can bunch it up like you can with the digger as well as take forwards or backwards.
The hedgecutter is seeing some savage use. Stopping fairly frequently to replace blades 🫣🤣
The hedgecutter is seeing some savage use. Stopping fairly frequently to replace blades 🫣🤣View attachment 85173View attachment 85174View attachment 85175View attachment 85176View attachment 85177View attachment 85178View attachment 85179View attachment 85180
Flail not better? I hate clearing up arisings...
he with the most kit wins 🤣
are those blades the right way up ? surely that would force them away from the fingers and snap them ?
Still doing a shift.
Next next winters wood or maybe the one after that.
Pondering if anyone's ever scrapped a 35? Or in 100 years time will they be highly sought after when anything with a ECU is long dead after electronic warfare has wiped them out 🤔
Came the closest I’ve ever come to running out of juice in the cherry picker whilst up in it 🫣🤣🤣
This clock has been stopped for years. Meetings have been had. Quotes have been sought. £10k including scaffolding etc…
FFS. I’ll take a look for you once I’ve fixed these gutters, it can’t be rocket science.
Up over the roof, into the access door behind. Nothing to it- can see some brass flakes in the box, that’s probably why the hour hand has stopped working.
“Take that the the clock specialist in town, call me when you get it back”.
Now the good news for the management committee, as I told them yesterday, is that my bill is only £5000…
Then a few more gutters that have slipped joints over a conservatory. Added a touch of silicon to try to stop them pulling apart, but your dammed if you do and dammed if you don’t. They were never hung properly in the first place- these ones do at least have a bit of board behind them, other areas just have the plastic brackets hanging on a single bolt from a steel rafter tab. No way of setting them up correctly, and with the movement of the brackets they keep slipping joints and have over the life of the conversion been sealed up so much that they just warp and twist and then overflow instead. Like I say, they can’t win unless they want rise and fall brackets installed everywhere, which would be mega money.
