Plated to that as it's unbrakedLittle blue trailer be nice for Dexta with its pin hitch. Only 1.5t on data plate which surprises me .
Ah. Makes sense. nice little thing. Never seen one that size with twin wheels before. 5/6ft x 12ft I think. £850 I think it went for.Plated to that as it's unbraked![]()
I have a bit of plastic tube that self tapped into the hole, then small funnel and a bit of patienceIs this a joke? Never come across such a spasticated track motor filling port in my life. First time changing the Wackers and it's literally taken me half an hour per side to get the oil in there. Can't fit the nozzle from the bottle of EP90 in there so made a little funnel which means I can drip in a tea spoon at a time where most of it spills out around the filler hole. There must be an easier way to do this??. Takeuchi you could waggle your finger in the hole! This one is smaller than a drinking straw
Yeah was thinking something along those line for next time but the hole is probably only 8mm so not exactly alot of room to get any thing and still allow the gear oil in too.I have a bit of plastic tube that self tapped into the hole, then small funnel and a bit of patienceand fill hole to top
shringeYeah was thinking something along those line for next time but the hole is probably only 8mm so not exactly alot of room to get any thing and still allow the gear oil in too.
I bought a big plastic syringeIs this a joke? Never come across such a spasticated track motor filling port in my life. First time changing the Wackers and it's literally taken me half an hour per side to get the oil in there. Can't fit the nozzle from the bottle of EP90 in there so made a little funnel which means I can drip in a tea spoon at a time where most of it spills out around the filler hole. There must be an easier way to do this??. Takeuchi you could waggle your finger in the hole! This one is smaller than a drinking straw
was exactly what I was going to suggest - oil syringeshringe![]()
Probably not a bad shout actually if I can find one big enoughshringe![]()
If the hose fits in that would be just the job
Respectfully, those are wank. They never draw properly, the seals leak and the cap threads lock together.
I was looking for a metal bodied one like I have but couldn't find a listing .... that looks a nice unitRespectfully, those are wank. They never draw properly, the seals leak and the cap threads lock together.
I switched to these and they have changed my life. They also come with a selection of tubes, some narrow enough to do to fill ports that OP is struggling with.
Bit expensive but at work I use an OilSafe pump and 5 litre container. My go to for finals on anything.I was looking for a metal bodied one like I have but couldn't find a listing .... that looks a nice unit
yeh got a couple of pumps for tranny filling ... one lever type in the neck of a 25l drum and an old rotary which is my favourite - bit like this - mine has a nice tapered nozzle and is probably as old as meBit expensive but at work I use an OilSafe pump and 5 litre container. My go to for finals on anything.
I find the metal type just as bad as the first one you posted. Seals end up bypassing.I was looking for a metal bodied one like I have but couldn't find a listing .... that looks a nice unit
might struggle with EP90
