Flip the bar every other sharpen to keep the wear even…
It’s a long running joke amongst arb people that you can tell an amateur because they will make a comment about the bar being upside down.
Sorry mate, I don’t make the rules 😂
Ouch 😣
My chainsaw ticket is from the last Millennium so I have forgotton that trick 🤦‍♀️
First tank of the year , forgot what a lot there is to organise 🤨
I know its been talked about on other threads but must find a way to knock up some dry mix that doesnt involve another trip with truck, 3t st dumper is wrong shape completely to get it mixed without thoroughly abusing bucket and dumper skip .....perhaps a mixer bucket 🤷‍♂️
small skip? or old 600 gal steel diesel tank cut in half for two units (used to use them for scrap skips in my yard) and always had a decent supply of 'em - " can you get rid of this old diesel tank for me please? " :rolleyes:;):giggle:
C
Cal919
Just shy of 2 weeks into the driveway on our nightmare job that is now at 3 1/2 years. Its slow going but will look the muts nuts when done. Its working out about 4fans per day per man laying thats with a man on cuts and being fed blocks.
View attachment 81686View attachment 81687View attachment 81690
Delivery to yard was late so had a minute on this little plate, starts but then spews oil out of the exhaust pipe and gets grumpy, sack it off to the engine graveyard and put a replacement engine on is probably best, no spapped valve springs 🤷‍♂️View attachment 81688View attachment 81689
Pan mixer
Cheers. I'm a while off yet got to resubmit planning to get exemption on a 14k Biodiversity charge! Just getting my ducks 🦆 in a row.
I’ve just had to do this, not to get an exemption but the opposite 🤦‍♂️ you can do a S73 - variation of condition , will basically re decide your planning but only the the specific aspect - ie they can’t fail it on anything else!
Yeah it's one of the reasons I stick to a straight tip. when doing my own bits of concrete I have found no simpler or quicker way than simply mixing it up in the 3t terex.
Which suppliers do you get to quote and layout?
I'd be interested in giving it a go but not sure on my plumbing skills for the connections. Might be worth a few hundred quid for a plumber for a day on a one off. Especially if they have the gear.
The manifold connections are really easy - they use a specific type of compression fitting that go together well. As the pipes are connected before you pour the screed you have quite a bit of wiggle-room within the floor loops, so it isn’t critical that your terminations are the exact length.
