Silversabre
Playing at setting out kerb lines today. Slowly getting the hang of it.
Don't know if you have one of these yet but if not I'd advise you invest so as you can easily set the tapes, just need to change the pole height to 170 and will give you the tape down from top of pin.
Mini Prism Pole 120mm - Surveying -UK Seller - VAT Invoice | eBay UK
Compatible prism height: 25 mm. Removable tip. Easy to use.
www.ebay.co.uk
Then it's good to have one on these quick release adaptors so as your able to quickly pop off the pole to set the tapes
QUICK RELEASE ADAPTER KIT FOR PRISM POLE GPS SURVEYING TOPCON TRIMBLE SWISS TYPE | eBay UK
Find many great new & used options and get the best deals for QUICK RELEASE ADAPTER KIT FOR PRISM POLE GPS SURVEYING TOPCON TRIMBLE SWISS TYPE at the best online prices at eBay UK! Free delivery for many products!
www.ebay.co.uk
Finally get yourself a bipod for the pole to keep the controller out of the mud unless you're got an assistant to hold it or do the knocking in? And then a set of these
